Question about Dryers
Dryer makes loud noise
Sears Kenmore Stacked Washer/Dryer Model 417.99680400: Dryer works but makes loud noise when running.
  • 1 more comment
  • beaven_ploch Jul 15, 2009
    Do these instructions apply to Kenmore stacked dryers?
  • Anonymous Mar 25, 2014
    Makes a loud noise when running
    Makes a loud noise when running I have a Danby kegarator
  • Dryers Master
  • 8,220 Answers
Probably a bad set of glides.
Dryer makes loud noise - ea82af1.jpgor worse.Check out my BLOG on this
Posted on May 20, 2009
  • Dan Webster
    Dan Webster Jul 17, 2009
    I do not go to the Kenmore site so I cannot tell you anymore than I know unless you could send pic of machine to me.
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Dryer makes loud sqeeking noise
What is the model number of the unit?
Nov 06, 2012 | Kenmore 98702 Stacked Washer/Dryer
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
My dryer is making this loud noise. It sounds like the washer machine... What could I do to fix? What could the problem be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ouireq
Mar 10, 2010 | Kenmore 98702 Stacked Washer/Dryer
My Kenmore 417.94812301 stacked washer/dryer makes a horrible squeaking noise when the dryer is on. It is not overloaded.
What you need to due is take front off dryer and either you're blower is making the noise, or the idler pulley and even the support wheels could be as well
Feb 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Jan 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
227 people viewed this question
Top Dryers Experts
