Question about TecnoWind TWD90 Kitchen Hood
Need new switch for tecnowind dta01
Need newvswitch and wiring to motor
Tecnowind DTA01 motor not working
Check the motor for free running with an external voltage, check if the motor is jammed, if so remove to free with lubrication with light oil.
if not the motor is faulty or there is no power from the control board. It can be failure of the driver/relay to the motor.
Apr 27, 2011 | Microwave Ovens
How do you change the light bulbs on a Tecnowind hood
With a thin blade carefully prise off the metal glass holder. Be carefully as glass is loose inside the metal ring. Replace with 20w bulb.
Oct 02, 2010 | TecnoWind TWD90 Kitchen Hood
Where do I find a replacement motor?
May I get the make and model # to help you more.
Jul 28, 2010 | TecnoWind 75 cm (approx. 30 in.) Classic...
Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Apr 03, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
I need to jump the drivers side window up
use a paper clip one way it will go down and the other way it will go up
Feb 28, 2009 | 2000 Chevrolet Monte Carlo
TecnoWind TWD90 Kitchen Hood Logo
73 people viewed this question
Top TecnoWind Kitchen Ranges Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Anthony Kelly
Anthony Kelly
Are you a TecnoWind Kitchen Range Expert? Answer questions, earn points and help others
