Question about GE Spacemaker WSLP1100D Top Load Washer
Extremely Load spin cycle
When our washer is in the spin cycle it is very very loud; this problem just started within the past week and a half....it's not shifting our moving around, it sounds like an airplane getting ready to take off.
  • Don57 Oct 20, 2007
    Thanks!  This confirms my suspicion....
  • 38 Answers
Lift lid, lift off top of agitator, lift out plastic seal, take out bolt, lift out agitator, remove the two horizontal screws which holds drum to shaft (chances are, one is broken, but its advisable to change both) replace and tighten all the way.
Posted on Jun 01, 2008
Lvghty
Posted on Mar 25, 2008
  • 164 Answers
The bearing on the tub is shot. depending on the make and model you might want a pro to look at it. depending on the age you might just want to replace it
Posted on Oct 19, 2007
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore elite he5 gas dryer and when it is turned on it will not spin. Can you tell me why?
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings OTHER WISE CHECK FOR A LOOSE WORN BELT
Feb 15, 2015 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Spin cycle is very loud, used to be very quiet.
It could be Quite a few things either not level to the ground or off track on the inside. try running washer without clothes see if it still makes that sound.
Jun 25, 2009 | 2006 Maybach 62
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Loud dry sounding spin cycle
cabrio and calypso have some issues with either main bearing problems or brake drive issues, either or this is an expensive fix, so if you have an extended wty, call your service provider, if not, just replace it, repair most likely in excess of 600.
Jun 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Loud Clicking noise only for the first 30-40 seconds of spin cycle.
You may have something caught in the pump impeller. I have found nails, screws, drill bits, paper clips and other small items that some how make their way past the wash tub and into the drain line. I would inspect the drain pump. Remove as much water as you can. Using a wet/dry shop vac to pull water through the drain hose is the best way to drain all residual water from the pump and drain lines. Remove the inlet line first and inspect the pump impeller. Chances are, you have something stuck causing the impeller to rub against it. If this has gone on too long, you may have some damage to the pump. I hope this is helpful to you.
Jul 05, 2007 | Maytag Atlantis MAV6000 Top Load Washer
GE Spacemaker WSLP1100D Top Load Washer Logo
252 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
