Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 65hdx82 convergence problem, pincushion
The picture on my Toshiba 65hdx82 has gone screwy; it's pincushioned badly and the convergence is off and changes from time to time. Manually adjusting convergence both red and blue move. I also found enough information on the internet to get into the service menu and do some convergence adjustment there--just enough to see that all three move.
I've read that one color not moving is a tell tale of bad convergence amps but they all move. Does anyone have any suggestions? I have seen some vague references to bad eproms on the digital convergence units but not enough information to really be helpful. Also, I can't find the service manual for this unit. If anyone could send me one that would be FANTASTIC. I do appreciate any help I can get. THANKS
I am pretty good with a soldering station and desoldering tools, have a fluke multi-meter handy, and even a tektronix scope if need be. :)
  • Toshiba Master
  • 3,459 Answers
Your TV most likely a failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your Toshiba 65hdx82 convergence problem, pincushion - 0667c5f.png chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
Moderate pincushion upon turn on of Toshiba 20AF41, and after several minutes the pincushion slowly is corrected and the screen is normal. It is a frustating intermittent since there is only a very few...
That sounds like either a capacitor, usually known as the S correction capacitor or a dry joint on the convergeance board. A can of freezer will help you locate the fault.
Hope that helps.
Nov 19, 2010 | Televison & Video
Occasionally the picture snaps into what looks like a pincushion.
it is infact pincushioning.. these tv's have a maze of boards.. try to contact manufactuer about pincushion pcb also try to auto converge colours if you can.
Dec 14, 2009 | Mitsubishi WS-55807 TV
The picture on the tv is curved in the middle sides if the screen how do i fix it to where the picture fills the whole screen?
Their are pincushion circuits the compensate for inward curvature. It is common for solder connections to break on the pincushion transformers or the connections where the transformer wire is wrapped around the connector pin. Careful inspection under a magnifying glass while manipulating the pin sometime will show hairline cracks in the solder. Their are also adjustments on the convergence board that will compensate. The adjustment potentiometers on the convergence board also have shown to be prone to solder cracking on the PC board
Oct 13, 2009 | Televison & Video
My rear projection 51mp392h has color distortion on the bottom third of the screen,it curves up in the middle. Is this a picture tube
Hello tj444,
This is not a picture tube problem. This could be what is called pincushion distortion. It is caused when the is a malfunction in the deflection coils and the inability to correct for the curvatures caused by the CRT. The pincushion distortion can also be caused by the degradation of the functionality of the convergence amplifiers in the TV set. I would suggest that you have a TV technician examine the deflection circuitry and the pincushion circuit, this would also include the convergence amplifiers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Toshiba 61h71 rear projection red pincushion
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Toshiba 61H71 61" Rear Projection...
Picture converges to the center -- "funnel" like
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
Dec 21, 2007 | Sharp 27J-S100 TV
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Convergence & Pincushion Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Aug 31, 2006 | Philips Magnavox 9P6034C 60" Rear...
Toshiba 50H82 50" Rear Projection Television Logo
720 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
