Question about Abbott Diabetes Care Optium EZ Blood Glucose Meters
Need to clear te memory - Abbott Diabetes Care Optium EZ Blood Glucose Meters
Casio Te-4000F Error E050
You should first check that you entered the correct digit for check tracking and not scanning file when you typed in the init code. Check your init code by performing a flag clear. If that is ok, Print out the memory allocation (program 5) and make sure you have allocated memory for check tracking.
May 12, 2014 | Casio Parts Cash Register PC Desktop
Cassio TE-4500F
You have put too many items into a guest check (tab). Finalise (pay off) the check to free up the memory.
If anyone needs a Casio TE-4500 or TE-4000F programming manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Dec 04, 2013 | Casio Parts Cash Register PC Desktop
How do i reset the casio te-2200-1 cash register till back to its manufacture settings
This is not advisable as you will lose a large amount of settings and data. If you are not familiar with memory allocation procedure, key allocation procedure, machine features settings and function settings, then it would pay to avoid a full RAM clear. It would be much easier to edit the existing programming to suit your business.
If you still want to RAM clear the machine and start again, you will need the tables from the Casio TE-2200 dealer manual:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
To program the basics such as Item names/ prices and receipt message, the user manual is what you need:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_users_manual.html
Sep 30, 2011 | Casio Parts Cash Register PC Desktop
My biostar motherboard G31-M7 TE have 2 slots to insert ram.. but one of the slots could not work.. whats the best solution to make it work?
Clean the faulty slot with anti static brush and isopropylene alcohol. Leave the motherboard for a few minutes to dry the cleaned slot. Inspect the defective slot carefully is there any pins are burnt or pins are misaligned. If so clear the burning and realign the pins. Reinsert the memory module and switch on.
Feb 14, 2011 | Biostar G31M7 TE (INTEL G31 MOTHERBOARD ...
I have just baught a second hand casio TE8500f cash register and every time i turn it on it displays init 1.flag clear 2.init2 and every button i press it then displays operator mistake
Highlight "flag clear" and press YES button. If it still does not work, you have a flat or (usually) faulty memory battery and it will need to be RAM cleared then re-programmed.
If anyone needs more informaton on the Casio TE-8000f or TE-8500f, the manuals are here:
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_programming_manual.html
Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_service_version_2_manual.html
Feb 11, 2011 | Casio Parts Cash Register PC Desktop
How can I clear the memory of a casio TE-4500F cash register so I can start from scratch, I have the user's manual.
Hi Nigel. If you are going to clear the whole machine, you will need the dealer programming manual so you can use the tables to work out the settings for your store. This one contains the information on RAM clearing, and full setup:
There is a preview of it there so you can see the difference between the prog and user manual
Jan 18, 2011 | Casio Parts Cash Register PC Desktop
How to reset the casio te4500 please
If you mean you want to clear all programming, you will have a big job ahead of you. You are going to need the MAC codes for RAM clearing and the features tables, so you will need the dealer manual. Then I can work you through memory allocation, keyboard layout and machine features set up.
Here are the manuals I would recommend for full set up:
TE-4500 dealer programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
TE-4500 user manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-4000F_and_TE-4500F_users_manual.html
Let me know when you are ready to continue with the RAM clear
Dec 28, 2010 | Casio Parts Cash Register PC Desktop
I have just bought a second hand casio TE-M80 cash register does anyone know how to clear all existing data from its memory
Which data did you need to clear? It might be easier to edit the program so you don't have so much work to do.
If anyone needs a Casio TE-M80 operation / programming manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-M80_users_and_programming_manual.html
Oct 26, 2010 | Casio Parts Cash Register PC Desktop
What do i type in to clear all previous transactions?
Try setting the mode switch to "Z" in reset mode, that should read and erase the trans. data in memory.
Feb 23, 2009 | Casio TE-2000 PC Desktop
Abbott Diabetes Care Optium EZ Blood Glucose Meters Logo
Top Abbott Diabetes Care Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Abbott Diabetes Care Health and Beauty Expert? Answer questions, earn points and help others
