Question about Maytag Dryers
Mede 300 vw maytag dryer
My dryer runs about 1 minute  then turns off and reads F23
5 Suggested Answers
  • 77 Answers
SOURCE: maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
Posted on May 14, 2009
  • 3 Answers
SOURCE: Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
Posted on Jun 24, 2009
  • 63 Answers
SOURCE: Odd sound after installation of gas dryer
Romove the '' Transportation Pins'' they are there to prevnt damage to the drum when the machine is being transported. If in doubt, call a CORGI registered gas engineer , not a DIY neighbour to check it out for gas safetyness. Do not take chances with gas for the sake of trying to save a bob or three.
Posted on Jul 11, 2009
  • 3230 Answers
SOURCE: Kenmore HE3 Gas Dryer F23 error
Well the F23 error code is an exhaust thermistor error. It indicates the thermistor is shorting out. This occurs after the thermistor heats up and that is why it happens after 2 minutes. Remember to unplug the power cord so there is no voltage present while servicing.
All you need to do is to pull the dryer out from the wall and be able to get to the back. If you can do this then you can replace the thermistor.
you can check out the below link for more information -
http://media.fotki.com/1_p,wksdqrtgsdbddsdxgtqsskgwtqkq,vi/wbrfdqtbtxwkrtsktgt/1/1303472/5961857/image59719img-or.gif
The thermistor part number is 8577274.
Good Luck!!
Thanks for using FixYa!!
Posted on Jul 07, 2010
Good Luck!!
Jul 07, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer wont stop running but i can turn it to off and it will turn off. doesnt matter
Either the motor has quit (less likely), or more likely the switch contact to the motor has become dirty or bent.  (Contact not closing all the way)  Standard repair is to replace the timer assembly.
This site should help you: http://ww.repairclinic.com/ Enter make, dryer, etc. They're down at this minute; they're a great source of information.
Jul 16, 2009 | Maytag Dryers
My Kenmore dryer is flashing a code F23 what does this mean?
F33 Possible Cause / Procedure 1.-Unplug washer or disconect power  2.- Check for wire harness condition to the pump and Central Contral Unit (CCU). 3.-Plug in the
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Was this helpful?
May 12, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Loose and broken baffle
d
Take off 4 door screws 2 right 2 left remove door pull front forward them two screws 5/16 in front with two brackets that hold top down. thats it just rotate drum and tighten or replace fin . ten minutes tops is all it takes.
my fin broke the screw holes so i will try longer screws if not i will leave off and run with two.
Mar 07, 2009 | Maytag MDE7600AY Electric Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
I just purchased a Duet Dryer, model #WED9400SW...When I try to dry clothes, after approx. 1 min., I get fault code F23...Can you help???
contact whirlpool factory service for help the number is in the owners manual, the f23 does not show up in my tech sheets, it is under warranty
Apr 12, 2008 | Dryers
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Dryers Logo
259 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
