Question about Maytag Performa PAV3200
Washing machine not going onto next cycle after it fills up..making a click sound
The washing machine is filling up, however it is not going onto the next cycle..and it is making a clicking sound
DOES NOT MAKE A CLICKING SOUND.
Posted on May 20, 2009
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
My machine will fill & go thru a wash cycle but wont rinse or spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Feb 08, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine stuck in fill cycle
It certainly sounds like the water level switch acting up. Do a couple of other checks first. Make sure you are not siphoning on the initial fill. Check your drain hose and make sure there is an air gap to the drain pipe. If you don't have a gap sometimes it will fill and siphon right out. Next would be to examine the level switch hose that runs to the tub. You want to make sure that there is no pin hole leaks in it causing this problem. Once you are satisfied the drain and tubing is ok, get another piece of tubing the same size and blow into the level switch when the machine is acting up. If the water stops, you can be almost certain it is the switch. Part number...3366847. It's important to do these checks because I have seen timers on this model mimic the water level switch. Catriver..post back.
Oct 16, 2006 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
192 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
