Question about Freezers
Water fails to drain away from frige compartment
Water gathers at V shape track above glass tray spills over have to wipe away with cloth then procedure starts all over again
    Sergeant:
    Champion:
  • 214 Answers
Sounds like you have a pluged drain tube.the tube runs from your freezer to the rear bottom of the fridge into a drip pan.If you can get to the tube from the outside just remove it and clean out.If not you will have to remove the rear panel in the freezer compartment and clean it out from there .by using a small wire or what ever you have to push the obstrution out.Most times you can just blow the obstruction out with air.After pour hot water down the tube and make sure it is draining good.If you have a lot of ice buld up you will need a defrost timer hope this gives you a fixya:)
Posted on May 20, 2009
  • tom wright
    tom wright May 30, 2009
    great advice keep it up:) LOL had to give mydelf a comment
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Oct 20, 2013 | Frigidaire Freezers
We appear to have a blockage in the pipe that takes liquid from the fride part of our FFSS70 model. Because of this we get water forming in the bottom of the fridge each day.We have tried all ways to try...
Hi Bob. First off let me say that a clogged compartment drain with ice in it can be a real pain. Portable hair dryers don't work because the water insulates the ice. You may not like the answer here but this is several decades of hands on exerience speaking. So here goes......
1. Unplug the unit.
2. Empty the contents of the freezer
3. Place a fan blowing into the freezer section for well over 2 hours.
(THIS MAKES A MESS so be ready with rags and a mop)
<After external fan period and mess period>
4. Get yourself a single strand of #14 gage household electrical wire with insulation. Strip the end of the wire about 1 inch on the very end of the wire, fold it back on itself so that there is not a sharp end. (Flat tight U Loop) and start pushing it through the drain. If you hit any blockages or elbows try bending the loop just slightly. (Just do not force it really hard as you may detach the drain tube from the freezer compartment. Measure the distance that you have traveled the wire through the drain. It is pretty much a straight shot top to under the bottom of the chassis at which point there are some bends. Once you know you have reached the bottom of the chassis... pour HOT water thru the drain and observe the lower catch tray in the bottom of the unit checking for water flow from the tube. Often the plastic tray in the bottom of the unit has water in it just as a result of normal defrosting. The end of the cabinet drain tube sits in that tray. Over time the dust and lint that collects forms an ugly goo in the plastic tray. That goo eventually dries out and can also encapsulate the end of the drain tube. Make sure to clean the drain pain and the end of the drain tube during this process.
If you have problems and there is water in the drain that you need to remove; a roast baster works pretty good for removal of the water near the drain.
While you have it manually defrosted do your best to clean the drain top and bottom. These 2 areas are where most blockages occur.
Once your all done cleaning... wipe the bottom catch tray dry.
Pour a measure amount of water 50 ml or so in the top drain.
Check to make sure you get 50 ml at the catch tray. If you do not get close to what you put in.. at least 45 ml. Then there is a problem with the drain tube. i.e Hole, pinch, fold etc.
Getting the unit to room temp... (Fan) and letting the room temp defrost the ice in the tube is the best way to clear this. Slow process but a must do. There really is not a fast way to do this. If you don't have access to a piece of wire... a larger LONG plastic ZIP / Cable / Spot tie (Like they use for handcuffs) will work well also.
Just a final note. I looked up your unit parts via Hotpoint UK.
http://www.hotpoint.co.uk/hotpoint (Model FFS70S)
There are 116 parts available and the drain is not listed.... be careful.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Hotpoint Freezers
Hi I have an upright Siemens freezer (model E000786) which is 9 years old. It still works well but I have found for the last couple of years that it needs defrosting more frequently due to the ice...
a full defrost will take,depending on room temperature,about 12 hours,DO NOT USE HOT WATER/SHARP OBLECTS.
you can use car deicer but it will leave a residue/smell that you can remove by wiping out with clorine bleach.make sure any drain holes are syringed out with clorine and wipe out any drip tray to stop smells.by drain away he probably means"dries naturally"
do make sure all food is wrapped/covered (clingfilm) to cut down on frost/condensation inside the unit.after a full defrost fill with your usual foodstuff and fill any space left with newspaper filled poly bags.(less airspace=more efficient)
Sep 01, 2010 | Siemens Freezers
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Feb 02, 2010 | Hotpoint Freezers
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer ice making compartment stays in lock mode
the thermostat in the ice machine is not working. its most likely tha the icemaker is a FSP whirlpool it's a lot surer to just replace the hole head and be done with it unless you'd like keep dealing with it.
Mar 18, 2009 | Freezers
Freezer "leaking" cold water on floor
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Dec 06, 2008 | Frigidaire 14.1 cu. ft. / 399 liter...
Refrigerator whirlpool model wrx38rwh6
Oct 26, 2008 | Freezers
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Freezers Logo
117 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
