Question about ViewSonic Computers & Internet
Viewsonic va503m touch not working properly
Done all calibrations also.
5 Suggested Answers
SOURCE: TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Posted on Dec 31, 2007
sharcnet
  • 2130 Answers
SOURCE: touch screen not working properly
If recalibration didn't work, then the touchscreen has failed. This NOT A FIRMWARE ISSUE!!
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on May 02, 2010
benmuti
  • 29 Answers
SOURCE: my micromax X510 touch pen
its as sign that its got shot life to live.get a new 1,
Posted on Jul 07, 2011
SOURCE: While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 te
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Posted on Feb 18, 2015
How do I re-calibrate my Garmin Nuvi 705 series. The touch screen isn't working properly.
Here is the procedure:
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done". More tips can be found here:
GPS Obsession Ham Radio Forum Garmin Nuvi Tips Tricks
Dec 28, 2014 | Garmin nuvi GPS
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Lava a10 touch screen is not working properly
Touch screen problem
If your touch screen is not working, there's just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jun 17, 2011 | Cell Phones
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
My touch screen doesn't work. i tried to calibrate it but it doesn't even go into calibration screen. please let me know how i can fix it. thank you
Since the touch screen is not working, what you have to do is to reset the device. To reset the device, turn it off and on to see if it does the job. If that does not do the job, then hold down the power off/on button for about 10 seconds, the device restarts, that way it should work, but if it does not still work, the only solution is for you to jeep calibrating the screen continuously till you get it done.
The proper process to calibrate your screen is for you to:
  1. Turn off your nuvi,
  2. press your finger on the upper left corner of the screen (that is before powering on),
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold on to the touch screen with your finger for about 30 seconds or more till the white calibration screen comes on(white screen with touch dot),
  5. Then follow the on screen information.
Try it several times till you get it to work. It does not just work the moment you try it, you have to try it over and over again.
Dec 24, 2010 | Garmin nuvi 205 GPS Receiver
Calibration not working wen i push buttons 1 4 7 * sos 3 6 9 # works so nothin on left of screen works so i cannot access phone menu to reset
Hi,what makes the calibration not working.is because the touch screen of the phone you are using is not functioning properly. And you will need to replace the touch pad of the phone for it to work properly again.
Sep 25, 2010 | Samsung Cell Phones
Screen rotates, pen doesn't
Is it maybe possible it is a hardware prob? maybe the directional sensor in the tablet was displadced.
BTW i have the same tablet and need an harddrive replacement/upgrade, how did you manage to do that? what kind of drive and where to buy? Viewsonic seems not so eager to help me out with that.
Best,
Fredrik
Apr 25, 2007 | ViewSonic Tablet PC V1100
Computers & Internet Logo
48 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
