Question about FreeMotion 330R Exercise Bike
Intensity not working
Even though the intensity level is increased, the exercise bike can be peddles easily.
Investigation based on the effect of light intensity on the rate of photosynthesis.state the hypothesis and variables
Well, your variables are in the statement of the topic. Light intensity and rate of photosynthesis. the independent variable could be the light intensity.
No light ( Intensity =0), no photosynthesis (rate=0). Increase the light intensity, the rate of photosynthesis should go up.
Hypothesis: As light intensity increases, the rate should (? ) go up.
Nov 07, 2013 | Chevrolet Bolt. Air distributor. Driver...
What is an upright exercise bike?
The upright is a traditional looking bike and gives you the option to stand up on the pedals and really crank up the intensity of your workout. These bikes also work on many muscle areas that are not active while riding recumbent bikes.
Aug 09, 2012 | Exercise & Fitness
Bought a bike xq max magnetic exercise bike but it is not working properly as it is quite stiff to cycle and does not have a smoothness needed for an exercise bike. The tension is at the lowest level but...
For whatever reason, looks like you have a machine needing service or adjustment.
Best to take it apart, and test each of the "systems" and see if you can find the mal-function.
I'd say either the adjustment handle, or the cable, or the mechanism is not working freely.
Cleaning, or oiling or parts replacement may be in order, depending on what part you find "binding" upon your inspection.
God bless your efforts.
Oct 02, 2017 | Sport & Outdoor - Others
Workout difficulty adjusting knob is broken
Remove the cover under it is a rubber wheel and spring and that has worn or the spring has lost the tention replace as needed.
Jul 14, 2009 | Cycling
My hair straightener stops working when i increase the level of intensity to dry hair, what can be the problem?
Sounds like a short in the unit. It can be taken apart and make certain all of the wires are tight. Not sure what what you mean by increase intensity but if it means you oull harder it may just be too much for the unit. Try not putting so much pressure on it. Good luck.
Aug 14, 2008 | Conair Professional Ceramic Hair...
FreeMotion 330R Exercise Bike Logo
37 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
