Question about ASUS Computers & Internet
Asus P5K-e Wifi/AP audio to drive surround speakers
Greetings!
I am trying to set up 5.1 channel surround sound with the on-board audioof Asus P5K-E / Wifi AP motherboard. The audio chip on this motherboardis Analog Devices AD1988B. I am using speakers (2-front, 2-rear and acenter - no subwoofer) from an old AIWA music system.
I've reached a point where I can hear test sounds from all the 5 speakers. However, my problem is, the volume on the front center speaker is really low.
I am wondering if the on board audio hardware is powerful enough todriver the speakers directly. Although the front-left and front-rightspeakers sound pretty good. The sound on two rear speakers is slightly low too, but is acceptable.
Anyone having similar problems? Any ideas?
If it is of any significance, the system runs Ubuntu 9.04 OS. The problem occurs even if I switch to Windows XP Pro.
Thanks,
Mahesh.
  • 3 Answers
Since the left and right speakers sound pretty good, there is no problem with the driver software, the problem is in the sound system itself. be sure to have your sound system be check by a professional technician
Posted on May 20, 2009
Asus P5k mono audio
Probably the Audio output socket is worn. They consist of a number of small sprung leaves and these can weaken over time.
Mar 21, 2013 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
No audio in asus p5k se
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps you W7
Apr 21, 2012 | ASUS P5KPL-AM SE Motherboard
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Setup powering down after 5 minutes of being on.
Enter you're bios & head to CPU section. There should be a section to check CPU & motherboard tempture. Sit back & watch the temp settings. (Check for over-heating which can & will shut down the system). It's best to do this with the case closed. Normal operation.
Did you add thermal grease between heat-sink & CPU. Same can happen if memory over-heats.
May 18, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Not driver audio asus p5k/p5kc
Please expand "audio problem" to a question giving symptoms etc.
I hope you don't tell your mechanic "car problem" when taking it in for repairs! LOL
Trouble with Speaker 5.1 +Vista + Asus P5k Motherboard. No Rear Speaker sound
Hi Perseo,
If you run through a speaker test in windows, and hear playback from all 5 speakers and the subwoofer, then your system is correctly connected, and working properly.
Vista uses a layered sound system that renders sound a bit differently than what you're used to on your previous system. As a result, it will most often refuse to project stereo sources in 5-channel surround, on it's own. it will just play them as stereo, and the bass will fill in whenever it can.
One possible way you could use to get around this, is to force the system to use all 5 speakers, through the driver. If you're using a realtek onboard card anything like mine (I have a p5k-VM board myself), this can be done by opening up the HD Audio Manager, and selecting the "Speaker Fill" option, under the Speaker Configuration" tab.
another option would be to load your media player you use to play music or movies, and see if there's an option to change speaker settings within the programs.
hope this helps!
Dec 30, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
639 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
