Question about Mitsubishi VS-55705 55" Rear Projection Television
VS-55705 Wont power on. Blinks 3 times fast when plugged in. When you press power it clicks on then off, then blinks 3 times fast. Diagnostic mode displayed a 1-2 blinks. HELP!~
  • Anonymous May 19, 2009
    What would cause the voltage to not be supplied? I just checked all the fuses and they are good.
premtech
  • 934 Answers
SOURCE: have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Posted on Dec 01, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WT-42311 won't turn back on!
Convergence IC are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
  • 179 Answers
SOURCE: I have a Mitsubishi WD-62525.
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Posted on Nov 17, 2008
SOURCE: re:have mitsu model # ws-65813 wont turn on
WS-65813 Mitsubishi Same problem with flashing light wont reset used to reset now only flashes tried to reset with pulling plug for 24 hrs reset circuit is not working as per all other people with this mits problem Dont want to give up this great crt projector
Please help
scottswire@comcast.net
Posted on Nov 19, 2008
  • 8457 Answers
SOURCE: wd 62327 DLP red 3 blinks 1 steady red light
Call for waranty repair if less than 3 months old.
Posted on Jan 08, 2010
Mitsubishi vs55705 tv will not turn on
Two things here:
1. This set MAY have the self check feature if made after 1999 or so: if power light (green?) comes on for a few seconds and goes off---on front of set press and hold both the input and menu buttons at same time for at least 5 seconds and release both.
If it has the feature the power light will blink a two digit error code like 2 blinks, 2 blinks and pause and repeat the code for a total of 5 times.
If set has been unplugged it will clear the buffer of errors--you will have to turn set on and when it fails repeat the test.
If you find an error code let me know what it is.
2. Set is old enough the issue may be one of bad solder connections that develop with age---this will require a different approach--look for error codes if the model has the self check feature already described first.
May 20, 2012 | Mitsubishi VS-55705 55" Rear Projection...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns off and standby light blinks. Blinks 3 times, pauses, blinks again 3 times.
Three blinks means technically 'B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.'
After a little more research i found this comment:
"Guys I have found the problem. (referring to T603 and R672) I have found mine anyway. When I replaced my projection lamp, I failed to push the lever all the way down, but this was not the problem, just something you need to be sure to check. The problem was the lamp door. This needs to be shut properly. I found another thread where a guy had tried the same thing. It worked. The door clicks hard at the end to set itself. This worked for me. Hope it helps you."
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
So my question is have you replaced the lamp?
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony KDF-E50A10 TV
My tv won't turn on
OK BUDDY IM NOT A HOE FIRST OF ALL AND SECOND LERN TO SPEEK GOOF
Nov 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
I have an IP3000 printer and each time it is turned on it goes into error mode (the on light blinks amber 5 times then turns green for about 1 second then it flashes amber again
I. Make sure the printer is off but is plugged in
II. Hold down [RESUME] (Triangle pointed down) and hold down [POWER]
and wait 5 seconds or so.
Release [RESUME] but Continue to hold [POWER]. Double click [RESUME].
then Release [POWER].
Press [RESUME], than [POWER]. This should cause the printer to print a
simple diagnostic that'll list it's ROM number and list CDR SENSOR=OK
in red for the last line.
Press [RESUME] twice then [POWER]] to print off the second diagnostic.
Press [POWER] by it self to exit service mode and return to being a
printer.
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Jun 04, 2009 | Canon I990 InkJet Photo Printer
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 11, 2007 | Televison & Video
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
