Question about Frigidaire Affinity ATF6000F Front Load Washer
Washer has dr when trying to start
Have a DR on my washer when try to hit start
  • Frigidaire Master
  • 3,361 Answers
Either the door is not closed or the door switch is bad.
Posted on May 20, 2009
Why is my frigidaire affinity atf600sfo washer displaying a DR when I push start?
Hi adakota5267, thanks for the post!
I understand that your Frigidaire washer, ATF600SF0, is now displaying DR. DR stands for door open or door problems, which could be an issue with your door switch or wiring issue. Sometimes the issue can be resolved by opening and closing your door once more. If the issue continues I would recommend having a technician out to your home to diagnose and repair the washer. -Matt
Jul 25, 2014 | Frigidaire Washing Machines
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
Why does the dr light keeps binking
Hello Gene Frank - Typically error code DR indicates an issue with the door switch and wiring not communicating correctly or closing properly. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective, contact a professional to move forward accurately.
Nov 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
Hope this helps!
Jun 25, 2010 | Washing Machines
Says "dr", will not start
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Dr 2 message
I just sorted this on my own dvd player. push HDD and DVD buttons on the front of the player together for 3+ secs. Menu will display DR-OFF. Do the same again menu will disolay DR-2. On the remote push mode and "2" together and ths will put the remote into DR-2 mode. All should now be well.
Aug 30, 2009 | Toshiba D-R2 DVD Recorder
I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
May 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
128 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
