Question about Refrigerators
I was pickeing away at the ice on frezer and i poked a hole in the plate for the frezer, i need to know if the fridge will still work or do i need to bye a new one
Poked a hole in the frezer, will fridge still work
  • Ken Bledsoe May 11, 2010
    You might be able to patch the hole with two part epoxy and then pull vacuum and recharge. If you have a buddy that has nothing to loose and has the tools. I fixed a unit for a friend couple years ago and still working good. It was a apartment size one he took it to use at work. It can be done.
  • steve
    steve May 11, 2010
    NO. Buy a new fridge.
  • 90 Answers
Yes , should still work as long as you didnt hole the coolant pipes. Use some putty or similar to block the hole.
Posted on May 20, 2009
How do I defrost the water line to ice maker on a Kenmore Coldspot model 5151200
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 24, 2015 | Kenmore Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Jul 15, 2014 | Samsung Refrigerators
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Was defrosting fridge... and was breaking up ice out with screwdriver. poked hole in metal shelf... spit air out.... what is this part and how much to replace?
Sorry to tell you, but you poked a hole in the evaperator. Would cost more to fix than buying a new refrigerator. Sorry.
May 28, 2011 | Kenmore Refrigerators
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
After i removed all the ice now its not cold at all
Hi, The most critical question following a defrost is this ( if the fridge no longer cools/freezes )...What method did you use to remove the ice ? If you "chipped" it away via a knife or other means of "chipping" or "picking" the ice from the evaporator as opposed to allowing it to melt, I would immediately suspect a hole in the evaporator. If that is the case the fridge is toast. I mean in theory it CAN be repaired, but the cost would be impractical...unless you know a tech who can epoxy the evap and recharge the system with gas (R134A). If that is even legal where you reside, there are specific laws regarding "sealed system repairs" from state to state, province to province, country to country, so you'll want to check the laws/by-laws where you live. Of course you should insure the compressor is operating as that would be essential for the unit to cool as well. I have to say though, holes in the evaporator are the most common culprit for a manual defrost fridge not cooling...following a client "chipping" off the ice. Let me know if this answered you question. Thanks for visiting "fixya" for your fridge inquiry and good luck. macmarkus :)
Apr 17, 2010 | Sanyo 4.4 cu. ft Counter-High...
FP E381T, lights won't stop flashing, fridge not cooling properly
There is another fan to draw air into fridge compartment- access via fridge: remove back panel (long plastic cover- just clips off). Remove control housing (again, just clips off- careful of wiring though). Fan is located up in this channel between fridge and freezer compartments. However, from what you are describing, I think you have a blockage in the freezer drain, causing a build up of ice in the freezer which blocks the air flow to fridge.  To check, remove rear panel of freezer (clips off- you need to press down two clips at top of panel, they can be tricky to get off!!). Disconnect fan motor wiring by unclipping plug connection, and remove sensor wire(white wire) so panel can be removed completely. Now have a look in the trough underneath the evaporator, and check for ice buil up- there should be no ice in this trough. If it is iced up, you need to defrost ice and then pour some water in the trough and see if it runs away. In the middle of the trough there is a small hole where the water should run down and away to collector tray at rear of fridge- if this hole is blocked, water won't run away, so builds up and freezes and blocks air flow to fridge. If hole is blocked, poke a wire down to unblock.
If in doubt, call in the experts- F+P fridges can be a bit fiddly getting apart, as everything clips together ( I worked for F+P for 10 years, and I still sometimes have problems getting panels off easily!!)
Good Luck!!
Mar 10, 2010 | Fisher Refrigerators
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
I called a repair man. I was charged $150.00 . It was the box at the botom left side of the fridge,under fridge. It's fixed .It took about 5min. to replace it. I could have done it my self. Reading FixYa pointed me in the right direction. Reading postings on FixYa! What a great place to recieve info! I am not sure what the part cost, if you were to install it your self. Not a big job it has two screws that holds it in place. I had to work, was in a bind for repair man. It was worth the $150.00 to have my food back in the fridge.
Jan 17, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
