Question about Watches
Have digital watch with only marking on it are PF PAM 352 and no manual. Can't figure out how to set it. Replaced battery with Duracell 392 button
3 Suggested Answers
SOURCE: Have a digital watch with
I have one of these watches also, but it has no battery- what battery does it take? If I can get a bettery for it, I will try to figure out the 12/24 hr mode setting and report back to you if you still need that.
Posted on Oct 06, 2011
I also have one of these watches, just replaced battery with a Duracell 392 button. Available at your nearest Wal Mart
Posted on Dec 31, 2013
Star Wars rebels led watch how to set time and date
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
Mar 14, 2015 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Casio 1170 ATC-1200 watch needs to have batteries changed
    I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
    Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
    To fix the Metric measurements:
    1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
    2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
    3. Hold down the adjust button, until the set screen comes up.
    4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
    You can adjust all the measurements from this screen.
    Jan 10, 2010 | Casio Watches
    Setting time/date on old Seiko
    With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
    Thanks for the follow-up.
    Feb 08, 2009 | Seiko Watches
    How to adjust time
    good morning ! to set your baby g casio watch , press the adjust button to make digit blinking when the digit blinking you can chagne the digit press the mode button,and next use the two to chagne digit after seting press the adjust button and the time is gona be normal,thanks po !..
    Sep 05, 2008 | Casio Baby-G BG169-2V Wrist Watch
    Casio g-shock watch
    http://world.casio.com/wat/download/en/manual/
    try for the manual from here.
    riz.
    Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
    Watches Logo
    415 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
