Question about Sony Rmyd034 Remote Control
Where is home button - Sony Rmyd034 Remote Control
Where is the home button
The Home Button is the only button on the face of the iPad. Apple's design philosophy revolves around the idea that less is better, which makes the home button one of the few ways to control the iPad outside of the onscreen controls. The most important use for the Home Button is to take you to the Home Screen.
Aug 11, 2017 | Cell Phones
Samsung Galaxy Core Prime Metro PC get home button back working right
Samsung Galaxy Core Prime (Metro PCS): Home button not working right:
Hello.. If you're HOME button on your phone is lagging or having issues..
Try turning off Samsung S Voice..
1. tap twice the HOME button, so that S Voice comes up.. or go to Apps, select S Voice
2. tap the (menu key) left button next to your HOME button, select settings
3. Uncheck the "Launch S Voice" option
samsunggalaxys3(HOMEBUTTONLAGFIX).mp4
Feb 11, 2016 | Samsung Cell Phones
Rogers yahoo home page
In order to set the Rogers Yahoo Home page, follow the instructions mentioned below:
Internet Explorer:
  1. Open Internet Explorer.
  2. Go to https://ca.rogers.yahoo.com/
  3. Click the Tools button, and then click Internet options.
  4. Under the General tab, Click Use Current
  5. Click OK.
Mozilla Firefox:
1.Open https://ca.rogers.yahoo.com/
2.Click the icon to the left of the web address, drag it to the Home button, and release.
3.Click Yes to set this as your home page.
Google Chrome:
1.Click the Chrome menu on the browser toolbar.
2.Select Settings.
3.Add the home button to the browser toolbar
4.Homepage button is off by default.
5.On the Settings page, select the "Show Home button" checkbox in the "Appearance" section.
6.Set your homepage
7.When the "Show Home button" checkbox is selected, a web address appears below it. Type in https://ca.rogers.yahoo.com/there.
GuruAid
Apr 30, 2014 | Computers & Internet
Iphone 4 home button not working properly.. Its working when i press hardly , how to fix it
In this case, your home button's connectors may have been misaligned and would require professional repair.
The good news is, you can still use your phone using its on-screen home button. Normally, this is used as an accessibility option, but it's also a common solution for those with non-functioning home buttons.
To enable the on-screen home button,
go to Settings > General > Accessibility > Assistive Touch. Turn Assistive Touch on, and you'll see a small circle appear on screen.
Tapping that circle gives you four options: Home, Siri, More (for things like multitasking and playback controls), and Favorites. In your case, ignore Favorites, but tap this on-screen button whenever you need to access your home screen, activate Siri, or get all the options you'd normally see when you double-tap the home button.
If the on-screen home button ever gets in the way, simply tap and hold to drag it anywhere else along the frame of your screen.
Mar 31, 2014 | Cell Phones
Ipod home button is stuck down
iPod home buttons fail all the time. If the button feels stuck in the down position, you no longer feel that distinct "pop" then it is a design issue and should be taken to the apple store for warranty work. If the iPod is out of warranty, then there are several shops that service home buttons. If the home button still "pops" as it should, then the issue is with moisture exposure. Sweat and wet hands while using the home button allow the moisture to seep into the home button area, eventually causing a corrosion buildup that slowly deteriorates the home buttons ability to do its simple job, after repeated exposure, it just has too much corrosion and stops working. If you of warranty period, check out my home button repairs, all with a 15 month warranty against defects, best price in the industry http://www.zfixit.com/ipod-touch-repairs/ c3f42093-2937-4241-8c7c-3b7ddbc184e5.jpg
Mar 24, 2012 | Apple iPod touch 3rd Generation MP3 Player
My i phone wont turn on i try to restarted now it wont turn on i try to hold the home button and the power button a pineapple apears and it just stays like thet
This may not fix it if you "jail broke"it:::
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone Smartphone
Iphone will not turn on, if I connect it to my computer it makes a noise but nothing happens on the screen, I have tried holding down the on/off and the home buttons.
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 12, 2010 | Apple iPhone Smartphone
My Iphone will not turn off when I hold the home button down. any suggestions?
It is not supposed to turn off when holding just the home button. In order to do a restart you hold the home button and power button down until you see the apple logo on the screen appear meaning your phone restarted. Holding the home button down just closes the program you were in and goes back to the home screen.
Nov 02, 2009 | Apple iPhone Smartphone
Iphone home button not working due to water damage
If you are familiar with repairing electronincs I would recommend opening the unit up and inspecting the internal components of the home button and the corresponding logic board connecting point for corrosion.
You can get a new home button for about $6 on eBay. Just eBay search for iPhone Home Button.
Hope this helps, Please Rate Me!
Jul 09, 2009 | Apple iPhone 3G
Home button on iPhone
press power/off button and home button at the same time for 10 seconds.
Aug 14, 2008 | Apple iPhone Smartphone
Sony Rmyd034 Remote Control Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
