Question about Kenmore 43142 Front Load Washer
417 capacity sears 417 420 42100
Model 417 420 42100 won't run high speed spin cycle, does rotate slowly one direction then the other, replaced motor speed board, did not fix the problem
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
IFIXALL
  • 868 Answers
SOURCE: Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
Posted on May 21, 2008
  • 63 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
Posted on Nov 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Posted on Mar 10, 2009
GodBlessU
  • 3513 Answers
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Posted on Aug 11, 2009
Why doesn't it spin in one direction?
only on wash cycle will a tub go both directions high speed spin is only one way all washers
Jun 27, 2015 | LG WM2301HR 4.2 cu.ft. Ultra Capacity...
417 front load washer -
have you cleaned the filter
if its two or three years old also check the motor brushes
Dec 31, 2013 | Sears Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Won't go into high speed spin at end of cycle.Spins slowly and reverses direction instead of high speed spin to remove water from clothes
Hi.This is a common problem for this model.You have a bad speed control board.The board is mounted on the rear lh base of unit .Replacement is easy, part costly.Two screws hold the board to the base and there are 2-3 quick disconnect plugs.You'll need model number to get correct one.Hope this helps .Please rate my response :)
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Kenmore 43142 Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
