Question about JVC KV-MR9000 9" Widescreen Monitor
Kv-mr 9 inch widescreen flip down monitor only shows grey screen
Monitor turns on and off and comes on when opened (normal function). Can not see picture, screen is only coming on and is grey in color. Monitor video cables are all plugged in. I am not sure if cable from switch box is bad, the actual module or the screen itself. Any help from anyone that has experienced something similar to this would be helpful. Have had the monitor for about three years now, trouble free. Up until now very happy with it. Unit is a KV-MR9000 9 inch widescreen
Mine was doing the same thing. i checked all the fuse connections and found 1 was bad and that solved my problem. good luck
Posted on Feb 17, 2010
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
I can not get the sound to go through the radio
Turn on FM modulator in OH monitor from the menu screen. Set station on screen, tune stereo to station.
Sep 24, 2010 | Directed DEI AutoMate OHD1021 Overhead LCD...
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
I woul like to have a bigger monitor? where to buy and how much?
I just purchased the Acer X233h widescreen monitor. I picked it up at Staples for 139. They had a sale on it. Not sure what normal price is. Anyway I couldn't be happier with the monitor. 40,000:1 contrast ratio and can run in full HD, 1920x1080. I will be using a Xbox 360 with the hdmi to dvi conversion to take full advantage of the HD. Regardless of not being in HD. The monitor is great for a lot of computing needs. Also I went from the Samsung Syncmaster 740N. Which is a 17" monitor. Going from that size to a 23" widescreen is a huge difference and watching movies is a better experience. Check it out for sure. Hope this helps!!
Dec 19, 2009 | Hanns.G Corporation HW173D Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Monitor Resolution Using Adobe Illustrator
make sure you have the display resolution set at a 16 x 9 display resolution of 1440 x 900
Sep 29, 2008 | Computers & Internet
Resolution problems following a power lock.
Turn on the on screen menu by pushing the number (1) button. Go down the menu to the memory recall function and Push the number (2) button to reset all the controls to factory settings. This should return you monitor to it normal function. If this does not solve your problem, you can call Envision customer support at this telephone number. 1-888-838-6388. They should be able to help you solve the problem. I hope this information helps you with your problem.
Jul 14, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Grey screen
Are you able to adjust the contrast or brightness? Try to turn them down to about 50%.
Jan 08, 2008 | HP f1905 19" Flat Panel LCD Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Car Audio & Video Logo
156 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
