Question about Dryers
Kenmore 970-c85192 dryer starts fine, but as it heats up a vibrating noise gradually gets louder
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: No Heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 21, 2009
dr appliance
  • 266 Answers
SOURCE: My Kenmore front loading dryer,
usually this is a drum roller replace both very inenspensive and u can order parts directly threw sears.com recheck model number get off appliance data tag on appliance
Posted on Jan 28, 2011
We have a Kenmroe dryer model 970-c85192-00 that only blows cold air right now.
Check the heating element and the thermal fuses for continuity first
Dec 29, 2012 | Dryers
My Kenmore front loading dryer, 970-C85192-00 starts drying with a load squeaking noise. Once it warms up it stops. Could it be a belt?
Jan 28, 2011 | Dryers
Dryer makes low freq rumble and associated vibration. Gradually increase in ampitude and vibration. Any suspects?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 04, 2010 | Kenmore 62602 Electric Dryer
Loud vibrating noise after warming up
heatman101
May 10, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Whirlpool model WGD62005W0 squeeks a lot when its started. It started gradually, then kept getting louder
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Nov 11, 2009 | Dryers
No Heat
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
