Question about Toshiba Qosmio G15 Notebook
Trying to replace my lcd screen, and unable to figure out how to get to the screws.
How do i remove the lcd screen on the toshiba qosmio G15R AV501?
My G15-AV501 Model PQG10U-00Y00L has a growing number of vertical white lines on the LCD screen. The laptop has been used very little and is not used for travel. It just sits on my desk. How do I fix...
hello sir this is Vga card problem.. u need to repair Vga card.. u can repair with rework station .. there is an example .. check this vedio.. in ur laptop VGA chip is biger then this.. Thanks
http://www.youtube.com/watch?v=FA6HcGFqzNE
Oct 15, 2010 | Toshiba G15-AV501 Qosmio Notebook
Video card went out on laptop. Replaced Motherboard. Works great, but now a thin line vertically on monitor. Hooked up to outside monitor and no line. Suspect LCD going out?
The problem description provided by you clearly reveals that the issue is with the LCD screen and a replacement is required.
This is a common problem. Most people just live with it. You can make it less noticeable by changing your background color on your desktop to a pure white color.
Oct 21, 2009 | Toshiba G15-AV501 Qosmio Notebook
Section of screen is fuzzy
Usually when you see this type of display problem the lcd display needs replacing. Do you know if it was bumped or dropped? That is usually what can cause this. The connector for the screen inside the lid gets shifted just enough to not make a proper contact. Can be fixed but it is a very fiddly thing to do. And usually involves bad language and a few hours of trial and eoor to get it right.
Replacement of the screen is much safer for your sanity and cheaper.
Jul 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Whats the trick to get into the BIOS of a Qosmio G15R-AV501?
Try F2 as soon as you turn on the laptop or even try F12 cause that would get you to the boot menu and you can choose enter setup from that point.
Feb 04, 2009 | Toshiba G15-AV501 Qosmio Notebook
I have a Toshiba Qosmio G15R and I need drivers......
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1299306&rpn=PQG10U&modelFilter=&selCategory=3&selFamily=804517&selModel=1299306%7CPQG10U
There u will find the ethernet drivers, the multimedia video controll drivers is only for the MCE.
The unkown device is something on your mobo, you need to findout what that is otherwise you wont be able to findout witch driver you missing.
Anyway, you will find all avalible drivers for your laptop and XP Pro if you follow that link above.
Good luck to you
If you find my answer helpfull, pls dont forget to vote
Dec 27, 2008 | Toshiba G15-AV501 Qosmio Notebook
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio G15-AV501 red lines in lcd hi i have a problem toshiba qosmio power on password.its model number(pqf10a-015008).how to solved the password removed.
pop the keyboard and look on the board next to the clock battery. You should see three jumper points, WITH THE POWER OUT AND ALL BATTERIES DISCONNECTED, short terminals 1 and 2 with the end of a flat bladed screwdriver. Replace all power sources and reconnect the power.
Nov 29, 2008 | Computers & Internet
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
See the below "copy & paste from another member" I don't know how sucessful these other owners were, but it's worth a try:
PNWSolutions
Rank:master_s.gif Master
Rating: 77%, 15 votes
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Aug 24, 2008 | Toshiba G15-AV501 Qosmio Notebook
Driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Dec 12, 2007 | Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio G15 Notebook Logo
192 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
