Question about Sirius Starmate ST2 Satellite Radio Receiver
My sirius radio displays 00180002. And no signal. What is wrong
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: My Sirius ST4 has signal issue after 10 minutes
This sounds like a component heat failure inside the unit on a circuit board. If it isn't in warranty, to figure out if that's what's going on, you can open it up and spray various components, one at a time, with Freon (Cool Spray at the Electronics Stores). When you hit the temperature sensitive part, the unit will work again. Go slow, and you should be able to pinpoint the bad part. Now the difficult part will be getting a replacement part, and if you're warranty's still good, better to let them fix it. I read where they're discontinued, so parts may be hard to get, and you might check Ebay for a replacement. Wish I had better news.
Posted on Jul 07, 2010
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
My 2008 ford focus sirius radio stopped working. sirius tried to reprogram, but it didn't work
Did Sirius resend a signal? If it is displaying their number it is likely that your subscription needs to be updated. The fact that it displays their info means it is likely receiving a signal. If it said "no tuner" or nothing at all, it would likely be the tuner. You can resend a signal online here:
http://www.siriusxm.com/activationhelp
If that does not work, replacement kits are available here:
http://www.tss-radio.com/products/isimple-factory-ipod-and-sirius-integration-for-ford-lincoln-mercury-vehicles-1
Jun 24, 2012 | 2008 Ford Focus SE Sedan
Reactivated Sirius Radio today. Display shows P1, p2.p3, etc with flashing channel 184. Unit will not work. Tried soft reset with Sirius, still no luck. Sirius said to go to the dealer and have them do a...
Disconnect negative wire from vehicle battery; wait minimum of 1-hour, then reconnect.
Turn on satellite radio, call Sirius tech support to have them resend activation signal. Stay on line with them since it may take them 2 - 3 tries.
Aug 27, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius not working after taking to dealership for unrelated problem
How did the dealership resolve the battery draw issue. Did they rewire the Sirius for you. If so they could have wired the unit wrong. If you have a newer vehicle most of the wires in the dash are a very light gauge and most fuctions are controlled by, what's called a Body Control Module. Some of these wires are not a very good place to draw power from not onlt could it damage your Sirius Radio it could damage the electronics in your car as well. I suggest getting it looked at by a professional. Then go from there.
Jan 11, 2007 | Sirius Satellite Radio Sirius Starbase...
Sirius sir-pnr1
I'm having the same problem and all they reccommend is unplug the unit from the back for ~2 minutes and then plug it back in and power up.
Jan 06, 2007 | Sirius Satellite Radio Sirius SIR-PNR1...
Sirius Starmate ST2 Satellite Radio Receiver Logo
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
