Question about Sharp ER-A440 Cash Register
Er-a440 frozen and constant beep
Freezes and beeps constantly.
2 Suggested Answers
Electroboy
  • 1646 Answers
SOURCE: We just got a Sharp ER-A440 register (used) and need to reprogram it and get the interface cable RS-232C. We are overwhelmed with how to use this, can you help?
Hi. You do not need an RS232 cable to program the machine. It can be programmed via the keyboard.
Firstly, it would pay to have the battery checked. They use an internal rechargeable battery which should be replaced every four years. If it hasn't been changed, it can leak on the circuit board and damage the machine. If the battery is not holding a charge, it will also lose your programming when the power is turned off. This is part of normal dealer servicing but you can't be sure that the previous owner has had it serviced and checked.
You will need to program department names. This is listed under "programming for departments - alphanumeric characters" in the instruction manual.To change the shop name on the receipt, see the section called "Programming various functions - programming of print messages".Once you have given those two a try, I can point you to any other parts of the manual you will need. Just let me know what else you want to set up.
Posted on Nov 23, 2011
My G5 freezes constantly. What can I do.
Try running Apple Hardware Test on the machine (it's one of the discs that came with the machine.) Also, if it's freezing by showing the spinning rainbow cursor (beachballing) you may have a failing hard drive. That wouldn't be uncommon for how old the machine is.
Feb 24, 2015 | Apple PowerMac G5 Dual Mac Desktop
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
IMac constant beeping and freezes when connected to the internet though wifi or ethernet
Only a guess.. Virus/malware/Trojan Try every other suggestion, hopefully you have back up, could try reloading saved mirror copy
Dec 12, 2012 | Apple iMac Computers & Internet
On power up just get contant beeping won't boot
constant beeping sound is usually a key on the keyboard that is stuck. If it is not constant, like long,short,long beeps, that may indicate a problem. Let me know it is is constant or a beep code.
Nov 23, 2010 | Acer Aspire 5315 Notebook
Constant beeping
replace the memory not to update the bios
Mar 04, 2010 | ASUS P4B533-E (P4B533-E/L/1394)...
My acer is 2 months old and constantly beeps, and freezes any idea on how to fix this?
Hi, if it beeps at the start when you start the laptop and it does not start the load the windows, then it is the issue with the RAM you need to get it replaced. If it beeps between normal window the it might be possible that there is problem with the Battery. As you said it is only 2 month old it should be under warrenty get it checked.
Feb 25, 2010 | Acer Aspire One PC Notebook
My eTrex Legend cx beeps constantly when turning off. The only solution I have found is to remove a battery. Any ideas?
I have the same problem. The unit is only 1 week old and I have used it maybe 5 times. The problem started a couple of days ago when I removed the USB connection from my Mac without ejecting it first. I think this might have screwed up the microSD card. I noticed that if I remove the microSD card the unit turns on and off normally. but is I have the microSD inserted, it turns on oK, works (apparnetly) Ok, but freezes with a constant beep when I turn it off.
Will try to reformat the card (any idea how to do that on the unit itself?)
Aug 18, 2009 | Garmin eTrex Legend Cx GPS Receiver
Constantly freezes up
get your phone flashed to the factory settings
May 18, 2009 | Cell Phones
My upside down fridge (4 to 5 years old) is beeping constantly from time to time. if i dont press the green flashing button inside the fridge it freezes the crisper s and the bottom shlef???
Most of the F and P refrigerators have this problem.
Its either faulty wire connection to one of the fans of the fan itself.
You need to fix them.
Oct 10, 2008 | Fisher and Paykel Refrigerators
Loud beeping noise
Hello!
The system memory is damage. you can replace the memory.
before you replace you can test the memory or remove the memory and clean it. after cleaning insert it back. some memory work with this solution. hope it work.
melnavz
Mar 18, 2008 | Acer TravelMate 2480 Notebook
Sharp ER-A440 Cash Register Logo
100 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
