Question about Exercise & Fitness
Sportcraft treadmill TX300
Code 3 ?
  • 15 Answers
SOURCE: TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Posted on Oct 17, 2009
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
SOURCE: My Sportcraft Treadmill has an error code 7 and
Try this website http://www.howtomendit.com/answers.php?id=102798. It got mine running. I haven't had time to test it to see if it is a permanent fix, but it's running...
Posted on Mar 21, 2010
SOURCE: Can I fix my Sportcraft TX400 Treadmill ?
adjusting the belt
Posted on Jun 19, 2010
  • 218 Answers
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 07, 2016 | Sportcraft Exercise & Fitness
My sportcraft tx2.5 will only show a #7 on the screen and will not do anything else
If you wish to get some details about Treadmill repair and service also error codes and cause the check the following link.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2016 | Sportcraft Exercise & Fitness
Where can I get a console-mother bo9ard for a Sportcraft TX 420 treadmill?
Assuming it is not a beanbag chair/treadmill, I suggest contcting Sportcraft directly for their input on where to obtain the board.
Jul 10, 2014 | Sportcraft Furniture
Mysportcraft tx300 treadmill keeps stopping and giving me an error 3
Did u find a solution? Mine just started doing the same thing
Feb 08, 2014 | Sportcraft Exercise & Fitness
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Error on system start
your system is failing it's Power on Self Test (known as POST) the beeps are a code which tells you where it is failing. unfortunately the codes mean different things for different motherboards, however common faults include Graphics card fault (try reseating) and Memory failure. If you look at the Manaul for the tx300 S2 there is a section on the diagnostic LEDs, I suggest you have a look, as it may help to diagnose your problem (it can identify faulty components) http://manuals.fujitsu-siemens.com/serverbooks/content/manuals/english/thb-d1899-d2099-en.pdf
Sep 11, 2007 | Fujitsu Siemens PRIMERGY TX300...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
