Question about BenQ PB8250 Multimedia Projector
Auto sync appears to not work properly
Trying to get the BenQ PB8250 to video sync with a computer at 1280 X 800 pixel output. Pressing the Auto button for > 3 sec doesn't bring up the described display with input and resolution, and does not change the projectors resolution. Is this resolution supported, and if so, is there a problem with the Auto sync circuit?
    Champion:
  • 205 Answers
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
Posted on Jul 07, 2009
  • 37 Answers
Be sure that you have your computer set up to display dual moniters, google how to set up dual moniters on vista, or Xp, or which ever OS you have.
Posted on Jul 12, 2009
4 Suggested Answers
jfpogie
  • 104 Answers
SOURCE: projector shutdown
your air filter of your projector is dirty, try cleaning it. tnx
Posted on Jan 30, 2008
  • 3422 Answers
SOURCE: BenQ PE7700
Check if the unit has a Filter Timer ? If it does have one - check the hours on it and reset it.
If the problem still occurs or there is no filter timer in the Menu - check that all your fans are running.
Hope this is of help
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 21, 2008
SOURCE: Projector shuts down ca 20 sec from start.
I have the same problem, however, my lamp wasn't replaced. Projector working great, just started today. Filter cleaned, reset lamp time, neither helped. Any luck yet?
Posted on Dec 25, 2009
Why do i have vertical lines on benq projector?
Probably because the signal going into the projector is a different resolution to the panel. The projector has an auto sync feature. But that only helps so far. Try changing the laptop resolution to match the native resolution of the projector (the pixels) and not the maximum resolution.
Aug 27, 2014 | BenQ Office Equipment & Supplies
Hello if a connect a pc to the beamer, i only get a black screen. but in the right corner it does says that it is connected :S
plug the projector end of the cable into a monitor and check that the video is OK.
then reconnect to beamer
make sure the rgb socket on beamer is configured for pc and not component video input
Jun 19, 2011 | BenQ PB8250 Multimedia Projector
I have a new BenQ G2220HD monitor connected to my MacBook as an external display. Since I've had it, it's had problems such as flickering pixels, lines that flicker, screen goes gray and flickers and is...
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
Jan 28, 2011 | BenQ G2220HD Monitor
How do I reset after bulb change BENQ PB8250
turn on the beamer and hold the exit button for 3 sec. it will ask you if you want to reset the bulb timer
Dec 10, 2010 | BenQ PB8250 Multimedia Projector
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
SIR I HAVE BENQ MP770 WE NEED COLOR WHEEL AND FOR PB8250 WE NEED POWER SUPPLY BOARD HOW MUCH AND CAN I ORDER TO YOU SIR?
wE CAN SUPPLY COLORWHEEL OF BENQ MP770 IN INDIA
MUMBAI PL CONACT -M.R.Corporation Mumbao +91 22 23802513 ,mrtelcom@vsnl.com
Sep 14, 2010 | BenQ Audio Players & Recorders
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
Benq 8250 projector shuts down
Hi david115
I've had this problem MANY a time before and what BenQ does wrong is that they only replace the two main fans at the back of the PB8250 , they should in fact replace both the fans and the Mainboard. This is unfortunately the only way to get around this problem.
Dec 03, 2008 | Office Equipment & Supplies
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ PB8250 Multimedia Projector Logo
149 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
