Question about Mantis Tiller
Engine won't keep running when using the throtle.
The motor will start after priming and chocking but when I squeeze the throttle is just dies down. I have fresh oil mix using Mantis oil have cleaned the air filter and a new spark plug last Spring. I have used it several times this Spring and it has always ran great. Don Rogers rogersdr@sbcglobal.net
  • rogersdr May 20, 2009
    Thanks longhorn- I will give that a try.
  • 376 Answers
Hi Don. There are two adjustment screws on the carburetor. Start the engine and while it is idling, turn the screw closest the engine (low speed adjustment) counterclockwise until it starts to falter, then back a 'hair' and try the throttle again. If that doesn't work, I would recommend doing what I usually do... put a new carb on and be done with it! Carb is a Zama C1U-K54A
Posted on May 19, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Need s step by step start up.New owner of old machine 5521bbc
    put machine in neutral pull the chock all the way out put throttle full open push in brake pedel all the way turn your key switch to start it if it hasnt run in a long time probably need to rebuild the carb if donsnt start try sqiurting some starting in the carb if it starts and dies it means carberator needs rebuilt you try to star it again this time before it dies keep it running with starting fluid just shoot short squirts in carb to keep it running do this for only 2 minutes if you keep doing it you will damage motor try that and see if it will run
    Sep 15, 2014 | Garden
    Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
    have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
    May 02, 2012 | Yamaha Boating
    My MAC 3227 trimmer will start an only run for a short time (less than a minute). It needs for the chock to be in the half chock position to start. If I move the chock to non-chock it stops. If I...
    remove the carburator.. It's plugged.
    disassemble and soak the body in fresh gasoline for about 10 mins.
    Blow out all the ports with small engine carb cleaner and reassemble.
    Drain the gas tank , clean it and refill with fresh gas mixture
    It doesn't take much to clog those little carbs
    May 23, 2011 | Garden
    My f150 4.6 stugles to stay on after i start it however if i keep my foot on the throtle long enough the engine comes alive with no knocking or smoke but when i remove my foot off it chockes with very low...
    you might try cleaning the throttle body first. Buy some good Throttle body cleaner and a old tooth brush take off the air intake hose to the engine, have a friend hold the gas pedal to the floor with the engine off and spray and scrub the throttle body good replace the tube crank it up and rev it up a little to clear out the cleaner this may fix your problem
    May 08, 2011 | Ford F-150 Cars & Trucks
    When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
    Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
    Cheers, Timo.
    Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
    I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
    Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
    Good Day.
    Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
    How can i tell if my ignition is going bad i can crank it over but as soon as i start to drive it shuts it self off
    First, make sure all your ignition components test out good; ignition coil, spark plugs, plug wires, power transformer, and even your alternator and battery.
    Next, check your fuel system; fuel pump, fuel filter, fuel pressure regulator, and even your fuel injectors. Many times a clogged fuel filter can cause idling and hesitation problems. Also check for any restricted air passages starting from your air filter, all the way to your throttle body and EGR valve.ry checking the tps sensor (throtle positioning sensor). if the tps sensor is not working right when the engine warms up the tps sensor will not allow the fuel pump to pump as much as it needs to keep the engine running. The reason it only happens when the engine warms up is because the throttle is chocked when the engine is cold so it does not take as much gas to run it.
    Aug 21, 2009 | 1985 Ford Ranger
    Engine will idle but when throtle is applid it dies
    Check fuel pressure & TPS. (Throttle Position Sensor)
    Jun 04, 2009 | 1999 Dodge Grand Caravan
    1990 Sierra, runs fine then just dies and will not start till pri
    Did you change the fuel presure regulator located in the throttle body?
    Nov 01, 2017 | 1990 GMC Sierra
    Mantis Tiller Logo
    966 people viewed this question
    Top Mantis Garden Experts
    paulfvincent
    Jim Parker
    Jim Parker
    Mike Squire
    Are you a Mantis Garden Expert? Answer questions, earn points and help others
