Question about RCA Car Audio & Video
What kind of Speakers are in a 06 cobalt?
Everything is original in my car but I want to kno wat kind of speakers they are? That is if they are RCA
  • 88 Answers
It comes stock with pioneer 6 1/2" speakers all around.
Posted on May 19, 2009
RCA & speaker hook up
I need code for : Blaupunkt GMBH 7 612 001 015, BNO 881. Made in Germany. Radio navigation AU Z1Z1B6079922
Thanks. my e-mail: max_zoki@hotmail.com
Best Regards.
Jul 15, 2013 | Car Audio & Video
Speakers
What kind of speakers do you have and what is it you are plugging them to? If those speakers have an RCA AUDIO IN at its back, then use an RCA cable. If the sound source does have an RCA AUDIO OUT then connecting it to your speakers should have no problem. If it doesn't have AUDIO OUT, but has PHONES socket, use a stereo DIN plug with an RCA plug at the other end to connect it to your speakers.
Jul 13, 2012 | Harman Kardon Audio Players & Recorders
I'm tryin too hook a jvc radio in a 85 caprice and need too kno wat wires too match with each other
yeah i can help you with this but i need to go to bed and need to know how many speakers where they are like the front doors and rear pastel shelf and how much you know about this sort of thing and do you have an electrical meter about £5 from maplins will do and the ability to fallow precise instructions and we are their believe me even if you have not done this before we should be able to sort it
Apr 09, 2011 | Car Audio & Video
The front speakers of my Chevrolet Cobalt do not work.
replace speakers or look for loose connection or is the fade adjustment turned to just the rear you would be suprised
Jul 02, 2010 | 2007 Chevrolet Cobalt Coupe
I have a vw polo 06. Can i hook up a sub plus rear speakers to the factory fitted cd player?
You can use a hi-low converter off your existing speakers. This will give you rca signal wires to run one or more amps, and speakers.
Jun 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Want to install after market speakers in 06 Chevy Cobalt...
they make a tool V-shaped that should be used for prying around the door panel..door airbags should not be triggered unless wiring for them is shorted, replacing speakers should not mess up any other wiring , fuses should be fine as are..
Jun 02, 2009 | 2006 Chevrolet Cobalt
Front two speakers just stopped working.
I have an 05 Cobalt that just experienced the same problem. I had my door panels off and my speakers appear to be dead.
If you have a multimeter, you can pull the speaker out and test to see if you get resistance across the two terminals. It should say on the speaker what the resistance should be (most likely 4 ohms). If you get no reading, you most likely will have to replace the speaker.
You could also test for AC voltage on the speaker wires. When the stereo is on, and set to a reasonably loud value, you should get a few volts. If you don't get any reading at the door, it may be either the wiring or the stereo. To determine which it is, you will have to take readings at the stereo output.
Hope this helps.
May 04, 2009 | 2006 Chevrolet Cobalt
OEM speaker sizes on 2008 F-150 ext cab
i belive the are around a 6 inch speaker tale out ur original speakers and measer across the speaker or if they are the crazy looking shape then i would take the original speaker down to the store u are going to and ask someone to help u find the shape and size
May 01, 2009 | Car Audio & Video
How to get the window crank off on 2dr 06 cobalt
there is a clip behind the handle. you should see something like a big plastic washer between handle and panel, the clip is between this washer and handle use a pick to get clip off
Nov 25, 2008 | 2006 Chevrolet Cobalt
My amp is not working
For the visonik, you should check your speakers. You can use a D-cell battery. Remove the speaker wires from the amp and connect each speaker across the battery (for no longer than a few seconds). The speaker should pop each time the wires are touched to the battery. If they don't, the speaker is defective (assuming the battery isn't dead).
If the speakers are OK, you need to confirm that you have a good signal feeding the amp. You can use the RCA cables from another working amp in the vehicle. Do this with the amp that had the power light lit.
If you have signal going to the amp and the speakers are OK, the only two things left are the power supply feeding the amp (from the battery) and the amp. If you have B+ and remote voltage AND a good ground, the amp is defective.
For the pyramid, the amplifier probably has shorted output transistors. The amplifier will have to be repaired.
Nov 16, 2007 | Visonik V117SX Car Audio Amplifier
Car Audio & Video Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
