Question about Lands Phones
Cybiotech cy 2126d
How i can set time
How do I convert $price per CY to $price per M3
1 cubic yard (CY) =.7645543 ( decimal point 76)cubic meters ( M3) so for example 10 CY @$1.00 per CY = $10.00 =$ 7.60 per cubic meter
Mar 11, 2017 | Cars & Trucks
HOW OLD IS MY GUITAR?
its a 2011
CY: Y = Yako (Taiwan) C = China. CY is followed by 2-digit year. CY appears on most models produced in China, and is by far the most common form. These forms are apparently associated with the change to Crafted in China, so post-1996 models only would have this form of serial number.
Some Chinese Gretsch's use a CY serial number. http://forums.fender.com/viewtopic.php?t=6299
Feb 18, 2015 | Fender Squier Standard Stratocaster...
I need to know how to set timing belt 4 cy 2.0liter with to cams
Would help if the vehicle details were included ,like what type of engine as on modern cars their is no timing marks on the gears anymore neither is their any keyway on the gears either they are a taper fit ,if you post the engine type then i should be able to tell you what to do ,if i dont know this engines timing marks i will instruct on how to set up engine with no timing marks at all
Nov 23, 2011 | Cars & Trucks
1300 1989 Golf/Fox torque settings cy engin block
about 75lbs ,i just pull them down to one grounch on my snap on bar then go over the head three times to make sure ,
Nov 21, 2010 | 1989 Volkswagen Golf
Turns over but back fires through carb replaced ignition control module,crank position sensor,coils. 1988 4 cy
You have done everything but what was needed. Whenever the engine backfire, it is always the timing problem It is out and must be set right. Please set the timing of the vehicle.
Dec 17, 2009 | Pontiac Fiero Cars & Trucks
Auto repair
Do you see the emission sticker under the hood, if the timing is adjustable (and I don't think it is) the spec will be listed there.
Oct 15, 2008 | 1993 Oldsmobile Achieva
Lands Phones Logo
24 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
