Question about Sony BRAVIA Televison & Video
Unable to tune in channel 10 & one - BRAVIA Sony Televison & Video
WoNt tune in channel 10 and when watching channel 10 through our hard Drive it constantly comes up with no signal every few minutes .
Could be that your signal strength for that channel is below what your tuner needs. Try throwing in a drop amp into your cable line to boost the signal and see what happens.
May 24, 2016 | Televison & Video
I need my radio code
can u explain the problme in detail
Jun 21, 2008 | Audio Players & Recorders
Toshiba TV, I can't tune channels, when I go to
Check whether the input is selected to AV. In AV mode, no tuning is possible. It it is in this mode now, switch it to TV mode.
Jan 13, 2013 | Televison & Video
I'm trying to set up the TV channels for the View Sonic 2750. I'm unable to program channels 3 & 4 to allow the cable converter box to work. The cable channels start at 181 and stop at 90 the air...
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Oct 17, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have an RX-DT680 unit on which i am trying to set the preset FM Stations to and am wondering what I have to do to accomplish this?
1. Select desired channel 2. Press " tuning memory" until "program" flashes 3. Press " preset tuning" up or down to select position 1-10 4. Press " tuning memory" again, flashing " program" disappears 5. Channel is now selected @ position 1-10 6. Find channel @ selected site by pressing "preset tuning" up or down
Oct 02, 2009 | Panasonic Audio Players & Recorders
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
Unable to tune the channels into the tv.
send me a picture of the front panel I will tell you how.
Apr 28, 2009 | Televison & Video
Tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Jan 30, 2008 | Symphonic ST419E TV
Suddenly cannot tune
Reset everthing in the menu. Mine does this every few months or so. I scroll thru the menu option until a come to a reset thing.
Dec 18, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
