Question about RCA Mikomi 5290925 15 in. LCD TV
Lenco 17ips17 hi,i have lenco dvl-2694 19" tv with no power i have tested all cylinder capacitors and all read good esr any help really appreciated
  • carl
    carl Dec 31, 2013
    sorry the psu is 17IPS19-4 V1 Thank you
  • RCA Master
  • 9,621 Answers
Look on www.shopjimmy.com. They have repair kits for many problem tv's. Lots of TV parts.
Posted on Jan 09, 2014
How do you know if the capacitors are bad if they are not swollen and if you cannot really see them because they are covered with a caulk-like material?
CAPACITOR:
A capacitor is a device that stores an electrical charge or energy on its plates. These plates are placed very close together with an insulator in between to prevent the plates from touching each other, and a type of dielectric. A capacitor can carry a voltage equal to the battery or input voltage. Usually a capacitor has more than two plates depending on the capacitance or dielectric type.Once charged the discharge rate can be influenced by another source. This action can create oscillation, or be used for electronic timing. The rate in witch the capacitor charges and discharges can be used to create a filter, or limit unwanted noise. There is lots more we can do with capacitors too.
HOW TO TEST THE CAPACITOR:
There are various methods for testing the capacitors. To short list, I would prefer to use one of the following two methods:
By ESR meter or by multimeter. Assuming that you would not be having the ESR tester just try to test it with the analog or digital meter just to get and idea whether it is defective or not. To test the capacitor do the following:
- Power OFF the device, disconnect it from the mains and wait for 15 minutes.
- Open or desolder one of the legs of the suspected capacitor.
- Take an analog or digital multimeter and set the range on Mag Ohms.
- Touch the probes of multimeter on each side of the capacitor legs and watch the dial (Polarity does not matter in this case).
- The needle of the analog meter or the digits of the digital meter will jump high and then comes back slowly. Reverse the probes and see if this happens again. If this is the case the capacitor is OK.
- If no reading or Zero is found the capacitor is open and is defective. Replace the capacitor.
- If the reading goes high, it is shorted and is defective. Replace the capacitor.
Hope that works. Thank you for visiting Fixya.
Jan 25, 2015 | LG 55LE5400 TV
Fixya Manuals
I assume you mean you changed capacitors on either the mainboard or power supply. My first question would be why you did this in the first place. If no power then you may have a additional problem other then capacitors. Unless the caps were blown or you tested them with a ESR meter then they might have not been bad.. Or they could have cause another component to go bad or vice versa depending on the circuit. Did you make sure you installed the new caps with the correct polarity? If so.. did you test the new caps with a CAP/ESR meter to make sure they were good? If cap were good, correctly installed, correct polarity, good soldering job.. then there is another bad compotent on the board some where.. with out proper testing it would be hard to say.. usually on & off issues are power/capacitor/mainboard related.
Nov 05, 2013 | Computers & Internet
WONT POWER UP GREEN INDICATOR LOGHT COMES ON FOR BOUT 5 SECONDS THEN GOES OFF,AND THATS ALL IT DOES...
Please check your power circuit capacitors for defective. Replace with new one if found it damaged.
Regards,
Oct 14, 2011 | Sanyo DP26648 LCD TV
LG TV has sound but no picture. what suggestions do you have? LG 55SL80
I would certainly say the power supply has a weak capacitor or two. I have not repaired this particular model. If you can remove the back cover and identify the power supply, you are off to a good start for repair. Look for a bulged or skinned capacitor. If they look fine, you will need an ESR meter to locate the bad capacitors. I would guess that at least two bad caps and there will be two more that are weak. Also, be sure to really, really look for bad grounds on power resistors and inverters, resolder as necessary. Good luck and thanks for asking!
Jul 28, 2011 | LG 55SL80 LCD TV
Hi, I was woundering if anybody woud know about this problem that I'm getting with Samsung tv model no LE32A41B. My TV comes on for approx 5 mins and then shuts itself off. Ive open up the back panel...
Hi:
Check the power supply ro4 puffy capacitors that look like they are about to burst on their tops, ususally there are two of them that will cause this problem. Replace with same value but change the voltage reating on the capacitor to 16volts.
Feb 16, 2011 | Samsung LE32A41B 32 in. HD-Ready LCD...
My monitor worked great for the period of 5 years or so...then one day it doesn't want to come on, the power light would flicker...anyway I removed the panel and looked for popped capacitors and I can't...
Bad caps can look normal but it they can have high ESR, but you should take some voltage readings first, it should have 5vdc and 12~16vdc when the monitor is plugged in but not turn on.
Post pictures of the caps also, many people told me the caps look OK until I see the pictures and they turn out to be bad. You need cap meter taht can read capacitance and ESR.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 07, 2011 | KDS K717s 17" LCD Monitor
Acoustic solutions lcd tv astv15id last used 2 months ago perfect ,switched on today perfect picture but no sound
Hi I know this was posted months ago but the answer may help others, I found the capacitor C852 1000Uf ,35v was bulging at the top which is on the power supply board the number C852 is for the acoustic solutions model lcd42762f1080p tv (but this info would apply to most acoustic tvs: WHEN TESTED THE CAPACITOR ON THE ESR METER READ OK, but cos it was bulging at the top I knew it was faulty, it seems that it was breaking down under load hope this help regards celestica
May 18, 2010 | Televison & Video
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There...
Replace thee 1000uf caps too. A capacitor meter will not test the ESR ( equivalent series resistance ) of the caps the cap meter will show them to be good but an ESR meter will show then to be bad. Also be sure to use low ESR caps. If you use general purpose aps like from Radio Shack it can damage the board board because of the ESR rating. The temp rating needs to be 105c or the new caps will blow out within a month because of the heat in the monitor case ( No fans ).
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 17, 2010 | Xerox XG-91D 19" LCD Monitor
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
DVL-V888
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Jul 26, 2008 | Pioneer DVL-V888 DVD Player
RCA Mikomi 5290925 15 in. LCD TV Logo
164 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
