Hi
I have a problem with my computer..when the computer start ...detect the harddisk and then restart again...I change the harddisk and the problems stills...
Thanks
Bye
I was taking out memory and then started the computer, I lisen a beep sound ..... I put it back memory... and started the computer again.... I didnt lisen beep sound....
You can't post conmments that contain an email address.
Check your bios to see if there is a hard drive option for compatability mode, you should change this value perhaps. What are your options in your bios?
have exactly the same problem, and same laptop, what operating system do you use, becuse my problems started after i changed to windows 7, had my one for 20 months as well more or less
This error comes when there is memory issue . Harddisk issue or RAM issue. For that if you have windows recovery disk you need to run disk checking program Most of this error comes becuase of hardddisk error. Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y" then it checks disk andf fix error if found any error on harddisk. then you can boot your windows. Thanks for using fixya. Please rate my solution if it hleps. Pls let me know if you need more assistanse. Many Thanks .
check in bios your harddisk is detected or not.
if your harddisk is not detected then u have open cpu then replug power and data cvable connection to your harddik and mother bord again.
then u can detect harddisk.
it is issue of loos connection betweeen harddisk and motherbord.
check it .
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Go into: MY COMPUTER> (RIGHT CLICK) C:/ DRIVE> TOOLS> THE FIRST (TOP) CHECK NOW BUTTON AND WHEN OPEN TICK THE UNTICKED BOXES> RESTART COMPUTER AND LET WINDOWS CHECK FOR ERRORS. DO NOT CANCEL
If any problems are fixed and HDD still making noise take it to a Computer SHop where the people will check it out. HOPE THIS HELPS
Hi, I think that your os has been crashed. So insert your disk and boot your system and check that your BIOS will boot from CD (Boot preference - CD ROM). And install a fresh copy of your os. Let me know the result.
you need to select ur harddisk as the first bootable device., that option is in BIOS settings. When switch on the system before loading OS press F2 to get the BIOS settings and select boot option in the menu and select your harddisk as the first bootable device. Restart the system now. If the same error is displayed your harddisk data cable may be failed or your harddisk may be corrupted...
