Question about Radio Communications
Amp blowing fuse when keyed up mic - Radio Communications
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Could be your final
Posted on Mar 03, 2017
    Novelist:
  • 500 Answers
What size fuse are you using? take the wattage / voltage = amp size you need.
ie... 12watts divide by 12 volts equals 1 amp.
or 60watts/12volts=5amps
but this is a estimate range. theres always surge amps that can be added etc..
rule of thumb.
40ch only types need 2amp-5amp.
the export styles and SSB40ch will need 5amp -8amp
Posted on Feb 04, 2014
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
Radio amp fuse blows
problem could be radio.10 amp fuse for ignition switch power up radio display the 30 amp fuse for radio amp system in which that circuit hot at all times.
Nov 18, 2013 | 1998 Lincoln Continental
Inline fuse blows when mic is keyed and talking
either wrong size fuse or wires are touching inside mike when keyed
Sep 09, 2013 | Radio Shack Radio Communications
We have a 2000 Solara that we just replaced the battery in, or rather, we tried, and the horn is now staying on continuously. It keeps blowing a 100 amp fuse, and does not have a key fob type alarm. The...
Why was the battery replaced? Theres no reason the the 100 amp fuse to blow unless the alternator is shorted or you hooked up the battery backwards. I think the 100 amp fuse goes to the alternator. If it was hooked up backwards then you may have engine computer damage.
Aug 25, 2011 | 2000 Toyota Camry Solara
My 02' mdx won't come out of park, keep blowing a 20 amp fuse. This fuse controls the Cruise, break lights, memory seat, horn and linkage. I have to manually delink. I have unhooked the comand...
Here is an idea, when do you blow the fuse key on, key on engine running, key on engine running hitting the break pedal? Try and get the key on without blowing fuse if possible, then one at a time try those circuit loads ie: horn, brake pedal and so on, if you isolate which load is pulling to many amps(blowing fuse) unplug that load itself, then restart testing, see if fuse stays ok. You can also substitue the fuse with a circuit breaker and unplug each load until click(of breaker) stops.
May 17, 2011 | 2003 Acura MDX
Fuse blows when I key the microphone. Why does this happen?
i am pretty sure something came loose or a connection went bad, now something is shorting, possibly to the chassis. if you think you know how to open it up and work on it than do it. Or take it to a tech and have them look at it. it should be a real quick, real simple fix.
Dec 04, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Gen lee blowing fuses when keying
What size fuse are you using? If you have a different power cord than that which came with the radio, such as one from a regular cb radio like a cobra 29, it will only have a 2.5a to 3a fuse, which will blow everytime you key up, since it is pulling to many amps. You need to have at least a 7.5a to 10a fuse. I use 7.5 amp fuses, because I have a 100 count box, and have no problems. The Stryker radio I have in front of me has a 10a fuse in its power cord from the factory, though the cord on my bench only has a 7.5a and has not blown.
If your radio still blows fuses after this, please let me know. You can message me here or email me at rollincbmods@yahoo.com.
Dean Pitts
Rollin CBs
Aug 29, 2008 | Connex 3300 240-Channels Base CB Radio
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Radio Communications Logo
160 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
