Question about Camelbak Bottle .75L
Water wont come out of the spout - Camelbak Bottle .75L
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Water wont come out spout
Remove the aerator from the end of the spout, then turn it on. If you get proper water flow the aerator is clogged, clean it or replace it.
Feb 27, 2015 | Moen Plumbing
Water leaks between the pull down spout and the bathroom tile
It sounds like your spout supply nipple has sprung a leak. There isn't much of any other way water can flow between your spout and tile wall. It's pretty important that you don't use the fixture until the problem is fixed. Because the water coming out that you see is also probably flowing into the wall and causing water damage and MOLD. You need to remove the spout and replace the nipple that is supplying the water to the spout. There could be a defect in your spout too, but likelihood of that is less than your nipple threads giving in to some electrolysis from the bronze/copper in the spout or somewhere in your water system. To prevent it from occurring again, use a brass nipple to replace the galvanized nipple in it now. Red brass, no yellow brass. Good luck with your problem and always know where and how to turn your water off to your house before attempting a plumbing repair.. Most spouts screw off. Counter clockwise, use a pair of channel locks by inserting the rubber coated handle into the opening on the spout then using the leverage of the channel locks to unscrew the spout off of the wall. It is not a repair that requires to have the water off to your home before attempting to repair. It only emits water when the tub valve is turned on. If it doesn't unscrew, twist it until the under side is up and you will see a slot where you can insert an allen wrench to loosen it and then slide off. Inspect the spout while it is in your hands to see if it is damaged of if the nipple sticking out is damaged. one of the two must be, because water flowing from behind the spout is definitely not normal and definitely something you need to fix right away, before your wall and floor behind your tub are damaged or start to grow mold.
May 04, 2014 | Delta Faucet Delta RP17453 Pull-Down...
Shower head leaks
Yes, the "switch" (to redirect the water to the shower head) is not closing/sealing completely (when you are using the tub spout.) Depending on the spout (model), you may have to replace the part where the "switch" is located, e.g. the spout.
Mar 03, 2014 | Plumbing
Shower head wont turn all the way off
the seal on the diverter may have fallen off, or bad/dirty diverter.
when the water is turned off, does the diverter return to "normally open" state? (no divert, goes directly through tub spout)
Apr 16, 2012 | Home
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Camelbak Bottle .75L Logo
612 people viewed this question
Top Camelbak Home Experts
Donni Steen
Tom Chichester
Are you a Camelbak Home Expert? Answer questions, earn points and help others
