Question about Ricoh Compatible Kit Type 4000 (002084MIU) -24047 (002084MIUC) Hard Drive
The copier is defaulting to duplex mode every time it exits sleep mode wondering how to stop this
My richo 4000sp is defaulting to duplex how do i stop that
  • 95 Answers
Duplex is selected on the print driver. Or the driver is using machine defaults, in that case the duplex needs to be set to off in the printer menu.
Posted on May 20, 2009
Give me minolta sp4000 code 0 d 50
The C0d50 code Duplex unit drive motor failure to turn.Turn ON the copier,open and close the front cover,pull out the duplex tray,clean the rollers alignement the belt.
Enter in the service mode press : STOP - 0 - STOP - 1,select F code history open and close the front cover,press Exit,Exit.
Jan 04, 2013 | Minolta Office Equipment & Supplies
How to take off sleep mode
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it
drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Oct 10, 2011 | Brother Office Equipment & Supplies
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Please, I need help with Richo MP7500 with error
SC534 D Fan error 5: duplex exhaust fan
The lock signal remained HIGH for 5 sec.
while the fan that draws air out of the duplex
unit was operating.
• Motor overload due to
obstacle interfering with
operation of the fan
• Fan harness loose,
disconnected, defective
• Fan defective
Jul 28, 2010 | Ricoh Aficio 1013F Copier
The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
1 Press Menu, 1, 8.
3 Press Stop/Exit.
Jun 15, 2010 | Brother IntelliFax-4100e Fax
How to stop sleep mode?
Sleep Mode
You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
it drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data or makes a copy. The default setting is 0 minutes.
1 Press Menu/Set, 1, 7.
time the machine is idle before it drops into sleep mode (00 to 99 minutes),
and then press Menu/Set.
3 Press Stop/Exit.
Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Program copier not to sleep at work
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Sep 27, 2007 | Xerox CopyCentre C128 Black and White...
Sleep mode
Press Menu/Set, 1, 6, 2 (2. Sleep Time should be displayed) Simultaneously press Start and Options at the same time Press Menu/Set Press Stop Exit This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Sep 13, 2006 | Brother IntelliFax-2820 Laser Fax
Computers & Internet Logo
161 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
