Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Loud rumbling noise in mastercool a/c
Mastercool seems to make a loud rumbling noise when on high. sounds like a plane taking off
  • electrostat8 May 19, 2009
    Could the pulley on the motor be adjusted any more to compensate for misadjustment
  • 148 Answers
Could be the fan is full off dust or something causing it to be out of balance
Posted on May 19, 2009
    Problem Solver:
  • 11 Answers
This type of cooler has "pillow bearings" where the squirrel cage fan rests in the frame. They must be lubricated with oil at least yearly. If they go dry the bearings can wear out and cause the noise. Oil them first to see if the noise is less and maybe you can get by without replacing them. If the noise is still there you may need a bearing replacement. Always turn off the power to the unit before you work on it.
Posted on Jun 20, 2009
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Jeep heat is not working and when I am driving has a loud rumbling sound every once in a while.when I am stopped car seems to idle to high and wants to take off by itself.
Sounds like you have several different problems.
For the heater you may just be low on fluid in the radiator. Your thermostat may also be stuck open.
The loud rumbling could be several things as well. You could have a CV boot, Universal that is going out or gone already, It could also be a brake rotor issue or a wheel bearing.
Does the idle ever operate in a normal range or does it always idle high and wants to take off.
Oct 16, 2013 | 1995 Jeep Grand Cherokee
2001 Toyota Camry. Loud rumble on start/warm-up, slightly decreasing after some drive time. Engine seems strained (with louder rumble and vibration) mostly in lower gears, accelerating and/or uphill. No...
Have you checked your oil and fluid levels in the engine and transmisson.
if it's a manual could the clutch be worn out causing the high rpm and thrust bearing noise in the clutch.
Jun 13, 2012 | Cars & Trucks
There is a loud rumbliing sound that seems to be coming from the motor (haier hlp140e) it's ability to heat also seems diminished. The rumbling used to happen on and off, but now it happens all the...
sounds like bearing noise and drum hitting on inside of outer body - naturally the drying process will be somewhat diminished and eventually the whole drum will compromised and collapse . Advice is to purchase a new dryer .
Jul 25, 2011 | Haier HLP140E Electric Portable Dryer
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
My washer machine sounds like a plane taking off when it goes into a spin cycle
IF ITS A FRONT LOADER ITS PROBEBLY THE REAR BEARING, DISCONECT THE POWER OPEN THE DOOR AND SPIN THE TUB, IF IT MAKES THE NOISE OR RUMBLE ITS THE REAR BEARING,
Jan 16, 2010 | Frigidaire Washing Machines
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,093 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
