Question about Dell LATITUDE Computers & Internet
Laptop display went off
Dell latitude D620 Monitor was turned off by fn key combination. Works with external CRT
    Sergeant:
  • Dell Expert
  • 464 Answers
Diconnect the video cable from the laptop to the monitor and do the Fn Key combination to see if it goes back to the laptop screen.
Posted on May 02, 2014
  • 21 Answers
SOURCE: Dell Latitude d620 display problem
Sounds like your computer has just bit the dust, do your self a favor and purchase a new one. This time buy an XP, it might be a little bit more, but you get what you pay for.
  `Nbryson
Posted on May 31, 2009
SOURCE: Dell Latitude D620 no display on main screen!!
Had a similar problem, some video "jitter" and then the screen washes out with backlight showing. ONLY HAPPENS when under battery power.
Cause: a recent reinstall of XP SP3 realized a newer video driver, intel integrated 945gm, than was on the Dell support site. This newer driver is problematic.
Download and install the Dell support site's OLDER video driver for the D620. A new battery won't help, only the older driver.
Larrie
Posted on Sep 22, 2009
Geekman
  • 32281 Answers
SOURCE: Aspire Notebook 5735-4774 won't display on external CRT monitor
If the video chip on the Aspire motherboard is OK then the image on the external monitor would be OK. If not then the video/motherboard is faulty.
To gain access to data on the hard disk, remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. The computer will see this as an external hard drive.
Alternately -
You can put the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Posted on Dec 21, 2009
Ray-Tosh
  • 124 Answers
SOURCE: I have dell latitude E6400,
@praskumar79
Things to check:
1. Is your display automatically transfer to the projetor right away when you plug the VGA/HDMI cable to the computer? If not, and Fn+F8 doesn't do anything, try to press the Windows Key+P (the windows key looks like this ray_tosh_1.jpg ). This will allow you to switch between displays. (see image below).
2. If you choose one of the display mode above and it still won't clone/extend the image on your computer to the projector, try to use a different cable. If still no go, try to re-install the display driver and see if that fixes it. If same issue, there might be a problem with your VGA/HDMI/Display port and needs to be serviced.
Good luck
Posted on Sep 12, 2011
Geekman
  • 32281 Answers
SOURCE: Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
Posted on May 30, 2012
Dell d620 sCREEN GOES BLACK AFTER WINDOWS SCREEN COMES UP. None of the normal Fn keystrokes help. i never make it to the login screen. Help?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 05, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell latitude D630 wont recognize projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Notebook
Wont see projector
Sep 19, 2012 | Dell Latitude D630 Laptop Computer PC...
Which key outputs video (screen) to projector
Sep 17, 2012 | Dell Latitude D510 Notebook
LCD only
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
How to hook up Dell laptop to Samsung Dlp tv?
Your Dell D620 only has a VGA Port for output to a external monitor or tv. Your TV will need to have a VGA Port too, otherwise you will need some type of adapter that goes between the laptop and the tv to convert to the type of connection the tv has (svideo, hdmi, dvi, etc.)
One you have the two connections set up to communicate with each other, just select the input source on the tv (pc, computer, hdmi, etc) and then reboot the computer if the image is not show.
After rebooting if the image is not shown, then you will need to toggle the display by some keystrokes. Press and Hold the Fn function key at the lower left hand portion of the keyboard, then hit the F8 key which toggles the display to be either on the laptop only, tv only, both the laptop and tv.
Apr 22, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Hi, I have a Dell Latitude D830. The display was off. I can connect extrenal monitor for current work. Please advise if I need replace display or motherboard ? Thanks Alex
Before replacing anything verify that your laptops display type didn't get changed to VGA out only.
look at your function keys (usually top one or two rows ) and look for the key that has a pc/monitor icon. with the machine powered up and connected to the external monitor press the function (FN button lower left of keyboard) and the video/monitor button at the same time. most laptops have 3 settings:
laptop display only, external display only and laptop and external display. Press the FN/Display button at lease 3 times waiting 3-5 seconds between keystrokes. I have seen this many times where the FN/display button keys are hit inadvertently.
Typically if the motherboard or video card fail the external monitor would not work either.
Jan 04, 2011 | Dell Latitude D830 Notebook
Dell Latitude D600 with video projector
Hi there if you have plugged into your external vga port all you have to do is press fn + f8 that should now show the image on both laptop and external ie projector
Regards Al "alstech"
Display Functions
<Fn><F8>
Switches the video image to the next display in the following sequence: the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, and an external DVI monitor only.
<Fn> + up-arrow key
Increases brightness on the integrated display only (not on an external monitor)
<Fn> + down-arrow key
Decreases brightness on the integrated display only (not on an external monitor)
May 29, 2009 | Dell Latitude D600 Notebook
Problems with external monitor
Typical issue is the second monitor resolution got set too high for the monitor to generate a picture. Go to display settings and adjust the resolution down to see if it comes back.
Mar 30, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
