Question about GE GTWN2800DWW 3.9 cu. ft. capacity top load washer
New washer won't spin
Brand new washer did 3 loads, now it won't spin. Washer is draining fine as far as I can tell. Agitator also is not agitating.
  • 641 Answers
SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Posted on Jun 02, 2006
  • 7 Answers
SOURCE: GE agitator does work
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Posted on Dec 22, 2007
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 5 Answers
SOURCE: ge washer is not agitating or spinning
change the timer.
Posted on May 28, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
The agitator in my washer won't agitate. I am able to pull the agitator right out of the machine
There is a high possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin. Thanks for contacting fixya.com
Nov 24, 2009 | Maytag LAT2600A Top Load Washer
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
Loud spin cycle
There is a good chance that the hub nut came loose and now the split ring is destroyed, maybe along with the hub that it sits on..
To inspect these parts, the agitator must be pulled sharply and abruptly off the agitator coupler. There are no mechanical fasteners that attach the agitator to the coupler, it snaps on. A strong strap under the agitator and a quick, swift pull will remove the agitator.( Don't hit your face, it hurts)
Removing the coupler, then the basket should reveal the source of the noise.
Jun 23, 2008 | GE Washing Machines
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
GE GTWN2800DWW 3.9 cu. ft. capacity top load washer Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
