Question about Radio Communications
Amp blows fuse when radio is keyed up - Radio Communications
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Whether it is the external or internal amp you may have to much power going through it.Could be a number of things from your finals to the reverse polarity diode.Check it out with the cover off and I'm sure you will find the problem.
Posted on Jan 15, 2014
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
I have a connex 4300hp . I have power until i key up ,then it blows the fuse . What size fuse does this require ?
There are many reasons for it to blow a fuse .Putting one in that is higher in amps won't help ,all it will do is prolong the reason it is blowing fuses. One reason could be IC 5 thats blowing them.
Jun 23, 2015 | Connex Radio Communications
Why do fuses blow
overload will blow you fuses.short to ground. wtich fuse is blowing?
Apr 16, 2014 | 1998 Acura TL
Radio amp fuse blows
problem could be radio.10 amp fuse for ignition switch power up radio display the 30 amp fuse for radio amp system in which that circuit hot at all times.
Nov 18, 2013 | 1998 Lincoln Continental
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
Just installed.as soon as i key mike inline fuse blows
check the swr's probably are high if it blows fuse. those should have a 5 amp fuse.
Jan 29, 2011 | Connex 3300 240-Channels Base CB Radio
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
Gen lee blowing fuses when keying
What size fuse are you using? If you have a different power cord than that which came with the radio, such as one from a regular cb radio like a cobra 29, it will only have a 2.5a to 3a fuse, which will blow everytime you key up, since it is pulling to many amps. You need to have at least a 7.5a to 10a fuse. I use 7.5 amp fuses, because I have a 100 count box, and have no problems. The Stryker radio I have in front of me has a 10a fuse in its power cord from the factory, though the cord on my bench only has a 7.5a and has not blown.
If your radio still blows fuses after this, please let me know. You can message me here or email me at rollincbmods@yahoo.com.
Dean Pitts
Rollin CBs
Aug 29, 2008 | Connex 3300 240-Channels Base CB Radio
Blowing fuses
Sound like: 1. Are you using the correct fuse rating?? 2. Are you supplying the correct voltage?? 3. You probably have final amp problems.. get an expert.
Feb 10, 2008 | Radio Communications
Radio Communications Logo
27 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
