Yamaha 410 enticer premix oil gas ratio - Audio Players & Recorders
2 Suggested Answers
SOURCE: snowmobile yamaha enticer manual for carberater
why don't you just check the compression if it's low fix it check the carbs make sure it works and make sure you bearing are goo your clutch your vbelt your track and that you have a the boggy wheels on it
Posted on Dec 10, 2009
I have a 1998 Yamaha GP 760 waverunner. 2 stroke engine. It's been sitting all winter. Not kicking over when I start. I read to use a premix instead of starter fluid, but what is the premix ratio?
Mary, you have to give a lot more information as to make , model , year, 2 or 4 stroke,capacity before anyone can answer this
modern 2 stroke engines use a metering pump for the correct oil/fuel ratio and it is not premix
and what is wrong that you need starter fluid in the first place
post again with all the information and some one will be able to help
Mar 13, 2016 | Motorcycles
What kind of oil do I need to put in the crankcase?
No oil goes into the crank case as it is a 2 stroke. The oil is premixed in the fuel at a 30-1 ratio.
The gear box takes 10w-30 se oil.
May 25, 2015 | 2003 Yamaha YZ 125
What is the fuel to oil ratio 1973 Yamaha lt2 100?@
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Premix And 2 Stroke Fuel Ratios For Your Dirt Bike
Fuel to oil mix ratio Vintage Enduro Discussions
Yamaha LT2 3 AT1C AT2 3 CT1C Combined Service Manual 1971 1973 Download... $15
Yamaha Lt2 1972 1973 Usa parts lists
http://mybikemanuals.com/yamaha
May 11, 2014 | Yamaha Motorcycles
Yz 250 specs
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 22, 2014 | 2003 Yamaha YZ 250
Oil to fuel ratio
Many of the 2 cycle motors use a 40:1 gas to oil mix. There should be a label on the motor that tells what the mixture should be. You also can buy a premixed container that has the gas ad oil mix all in one can. Just pour it in the gas tank, then pull the starter cord.
Mar 17, 2014 | Garden
Is it ok if i will not use my oil pump?mix oil directly at the gas tank
Not sure what your question is from how it's written?
But what I interpret is you mix your fuel in the gas tank of your bike - to this the answer is simple
NEVER DO THIS always premix in container then add.
If your asking what ratio to mix then it depends what riding you will be doing, race or recreational very hard and fast or just slow riding but most would run 40:1 to 50:1 ratio in a YZ125cc
regards Jamie
Sep 03, 2011 | 2003 Yamaha YZ 125
What is the ratio for mixing gas/oil for a 2001 yamaha vino scooter?
Hi, Bonnies460 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Premix or oil pump for an 04 yamaha vino 50cc
Yamaha YJ125S Service Manual
Yamaha YJ125T Owner Manual
Jul 17, 2011 | Yamaha Vino 125 Motorcycles
We need to put oil in our scooter, but have no idea if it's a 2-cycle, or 4-cycle engine... We own a 2004 Yamaha Scooter Attack... We bought 2-cycle motor oil, but it gives us ratio on the back of it,...
CHECK THE OIL DESCRIPTION ON THE BOTTLE, IF IT READS SUITIBLE FOR PREMIX AND AUTOLUBE,THEN THE OIL WOULD BE FINE FOR EITHER USE, PREMIX SIMPLY MEANS YOU MIX IT WITH THE PETROL AND THE ENGINE IS LUBRICATED AS THE FUEL ENTERS THE CYLINDER IN AN ATOMISED STATE. AUTO LUBE YOU WOULD PUT THE OIL INTO A CONTAINER IE A STORAGE BOTTLE BUILT INTO THE MACHINE, LIKE THE LITTLE HOLE NEXT TO THE GAS TANK YOU DESRIBED AND THE OIL IS FED BY A PUMP AS THE ENGINE RUNS TO LUBRICATE THE ENGINE , I CAN ASSUME IF YOU HAVE A STORAGE BOTTLE NEXT TO YOUR GAS TANK WHICH HAS SOME DESCRIPTION OF ENGINE OIL THEN YOUR MACHINE IS A 2 CYCLE AND NOT A 4 CYCLE IMPORTANT DO NOT ALOW THIS OIL TO EMPTY AS YOU WILL HAVE TO BLEED THE SYSTEM TO REMOVE AIR AND ALLOW THE OIL THROUGH.
PE. UK
Oct 30, 2010 | Yamaha G5 Motorcycles
I need to know the ratio of a gas and oil mix for a 1999 yamaha outboard motor 90 horse power already broke in...
I'am amazed it doesn't have an oil premix that gives it auto oil mix.If it doesn't than the mixture is 50/1.That is fuel /oil ratio.e.g. 50 litres of fuel to 1 litre of oil.Hope this helps
Apr 17, 2010 | Boating
Need to find the oil to petrol ratio for Husqvarna 132 HBV blower
50:1
50 parts fuel to 1 part oil. The easiest way is to purchase the little premix bottles of Husqvarna oil- one bottle to one gallon of fuel. You can find premix oil bottles at the dealer that sold the blower.
Nov 20, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
15 people viewed this question
 Grubhead
Grubhead
