Question about Acer Aspire One PC Notebook
Acer -Video Display Issue
OK Let's be simple. Acer Aspire One. had about 45 days - have bougfh 4 3 for gifts one for me. after about 3 minutes all video dissapates into blocks of blue - grey. I can boot to external monitor but in safe mode only - does not give me opportunity to do much else. Other than safe mode not even external monitor is avail. Seems to run hot
  • robbmavins May 21, 2009
    Hi - Thanks leecom72 for your post
    So this is the one of the weirdest situations that I have encountered.
    Just to refresh, I have an ACER Aspire One with Windows XP which I have now just about 7 weeks.
    I have purchased 4 of these and (3 for gifts and 2 of the gift ones had issues.
    (one had a sort of "minor" issue of the bios password not recognizing as it had to be capitals only - solved, eventually but only throught forums.).
    (Other had to be replaced as it would only boot after about 10 minutes - out of box.- solved by replacement)
    Now to mine - situation interesting
    Worked fine then developed a video issue which I am sure is a hardware issue but.
    I called Acer Support and the young lady I spoke to was very pleaseant but very little help. She advised me to boot up (of course) and then see if issue repeated. She had (forgive me, I know how hard Tech Support is but..) very limited knowledge of the platform and basically asked to do the basic "monkey button" knd of troubleshooting. (Yes it boots, yes it does what I just explained, why did you make me see if I can go into safe mode when I told you it made no diffrence, etc.) Also the description that was given for my problem made absolutly no sense.
    So Just to follow up.
    Problem
    Computer starts up normally, and boots successfully into Windows XP.
    After 2- 3 minutes, sometimes a little longer the screen starts to dissipate by about "eighths". By that I mean the bottom of the screen starts to go a greyish blue for about an eighth of the screen, then gradually continues in this fashion until the video display is entirely blueish grey. Also seems to run "hot" at the bottom where the rear vents are. - Could be a cooling fan issue.
    For the rest of the day the situation is the same. If I come back after say 24 hours, this process repeats itself (it boots, works OK then dissipates)
    Troubleshooting Steps
    Letting it cool down
    Works OK for about 15 minutes after sitting idle (unpowered) for 48 hours. then same issue.
    Plugging an external monitor
    Plugged an external Phillips monitor and it boots into safe mode OK and is visible on the external after the Laptop Screen goes grey-blue.
    So I can use and external monitor in safe mode.
    When using full Windows mode the external monitor does not show anything but "video connection not available".
    Have tried a Windows restore to previous "good" version, no difference.
    Have tried leecom72's suggestion and has not had an effect.
    Whe I first looked this up I came across someone with an almost identical situation but unfortunatly thought I had logged the site which I did not.
    Just curious as well as there seem to be several display and video issues that I have seen on the net, if anyone would care to comment on their situation.
    I am not anti-Acer, just a little frustrated
    Thank you
    Robb Mavins
    robbmavins @ gmail "dot" com
  • robbmavins May 27, 2009
    Flubbard
    Thanks, - for the external monitor issue - updated drivers and it does now work in both safe and full windows mode, however. of course still same issue with actual netbook sceen
  • Acer Master
  • 4,806 Answers
Hi there.
This could be 1 of 2 problems, lets start with the first.
#1 Bad display drivers
Boot the laptop into safe ( i am assuming you know how to do this by your post ) on the computer icon, right click and select manage, a new window will pop up and then select device manager, the list will populate with hardware that installed on the PC, look down the list for display adapters and click on the + sign on the left hand side to open the tree, then right click on the display adapter and select uninstall. Now restart the laptop and let it boot up as normal, if the display drivers were bad it will boot with the screen resolution as large, once you log in it should auto detect the display and install the drivers (you may have give it permission) if this works then that was the problem.
#2 Faulty graphics card.
Take advantage of the manufacturers warranty and send it in for repair as there will be nothing you can do about this kind of hardware failure.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 19, 2009
    Scholar:
  • 34 Answers
I have been working with three of the aspire ones and have not run into display issues. I would agree that it sounds like a hardware issue, either with the cooling unit or more likely with the display driver.
As for the external monitor, it is quite possible that the screen resolution is not matching between the two monitors when not in safe mode. In particular, the aspire one uses a funny 1024x600 which probably does not match the aspect resolution of most monitors.
Posted on May 27, 2009
Does ACER ASPIRE One 11.6" have camera ?
Yes'
General Brand Acer Series Aspire One Model AO751h-1401 Part# LU.S780Y.002 Operating System OS Provided Windows Vista Home Basic Processor CPU Type Intel Atom CPU Speed Z520 CPU L2 Cache 512KB Chipset Chipset Intel SCH US15W Display Screen Size 11.6" Widescreen Display Yes Display Type WXGA Max Resolution 1366 x 768 Display Feature LED backlight & Acer CrystalBrite Technology Graphics Graphics Processor Intel GMA 500 Video Memory Shared system memory 2GB Hard Drive HDD 250GB Hard Drive RPM 5400 RPM Hard Drive Interface SATA Netbook Camera Camera Type Acer Crystal Eye webcam Communications LAN 10/100Mbps WLAN 802.11b/g Wireless LAN Expansion / Connectivity USB 3 x USB 2.0 Video Ports 1 x VGA Audio Ports 1 x Headphone/Speaker/Line-Out Jack 1 x Microphone-in Jack Audio High-Definition Audio Support Speaker Built-in stereo speakers Input Device Touchpad Multi-gesture Touchpad (Circular-motion scrolling, pinch-action zoom, page flip) Keyboard Standard Card Reader Battery 3-cell Li-ion Battery (2200 mAh) Battery Life Up to 4-hours Manufacturer Warranty Labor 1 year limited Parts 1 year limited
Oct 14, 2011 | Acer Aspire One AO751h-1401 11.6-Inch...
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
I have a question i have acer aspire 5517 can i ask about the the microphone?is there a built in microphone in aspire 5517?i dont know because this laptop gave my friend in canada without manual.thanks
This model laptop does have a built-in microphone. Here are the details.
For a full specs go to this WEB site.
http://reviews.cnet.com/laptops/acer-aspire-5517-5997/4507-3121_7-33770835.html
  • Expansion Bays None
  • Expansion Slot(s) 2.0 (total) / 0.0 (free) x Memory - SO DIMM 200-pin
  • Interfaces 2.0 x Display / video - Input - Mini-phone stereo 3.5 mm,
    1.0 x Microphone - VGA - 15 pin HD D-Sub (HD-15),
    1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX - 4 pin USB Type A,
    1.0 x Network - Line-out/headphones - RJ-45,
    1.0 x Audio - Mini-phone 3.5 mm
Jul 15, 2011 | Acer Computers & Internet
Acer 5730 - Display blinks constantly
Please disable the User Account Control feature.
You can disable the UAC from User Accounts in Control Panel. Also, reinstlal the Video Driver to resolve the issue
Jun 30, 2010 | Acer Aspire 5610-4648 Notebook
My screen gets white before it starts and some time in the middle only yhe screen gets shut blank n i have to turn of directly using had been using my laptop for two years it now few days ago problem...
It might be due to faulty display driver, in this case you might need to reinstall display driver, but before that you can try one step-
1. Click on start.
2. Click on run.
3. Type msconfig.
4. Select Startup.
5. Uncheck all start up items.
6. Cick on Apply and then OK and cick on restart.
Hope this would fix the issue.
Mar 22, 2010 | Acer Aspire 5050-3242 Notebook
Acer Aspire SA10 Display Issue
Get an update for your video card's driver.
Jan 18, 2010 | Acer Aspire SA20 PC Desktop
ACER ASPIRE NOTEBOOK MODEL ASPIRE 4736ZG, IF I CHANGE RESOLUTION TO 1024X768 SCREEN SIZE BECOMES SMALL. HOW TO ADJUST VERTICAL AND HORIZONTAL SIZE SO WHOLE SCREEN CAN FILL IN.
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
Dec 16, 2009 | Acer Aspire 4720 Notebook
Gift claim
all u need to claim the gift for ur new acer laptop is that u can contact the shop from where u bought this laptop and alos u can go the acer website and email them for ur issue and they will definately get backk to u with ur free gift.....good luck.
Jan 26, 2009 | Acer Aspire 5100 Notebook
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
453 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
