Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
White smoke comes out while engine is running,running good.but only has 65 hr running time on it. Installed new oil filter,and changed oil. No Help. what next? Model # 40H777 Type 0242E1
  • doros75 May 20, 2009
    I tried everthing you said do but no help.
    One thing more whin i first crank the engine it takes about 5 Min before the smoke starts comming out, or when it gets hot.
    Could this be bad rings at such low howers?
  • Anonymous Mar 30, 2014
    has oil leak i cant see
  • 10,865 Answers
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
  • Joe Hogan May 20, 2009
    Your carbeurator is definitely gummed up. It should only take 2 or 3 pulls to be up and running.
    The carb. needs to be removed and soaked in cleaner for three hours, and possibly rebuilt. If this not within your ability range you will be money ahead to go to a pro.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Briggs & Str... Expert
  • 133 Answers
I would let the motor run for about a half hour to an hour it could be oil in your muffler if it is it will go away and not smoke anymore if it goes away then the next day you start it and it smokes again then goes away it is a valve seal if it doesnt go away it is either a bad head gasket (if its overhead valves) or a bad oil ring (sometimes they stick in the piston from sitting to long)
Posted on Jun 12, 2013
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
My mastercraft riding mower runs for about 5 minutes and dies then a big cloud of white smoke comes out
Hello Alan. I'm George. Do a compression check on the engine. You didn't mention the type of engine but it should have around 90 PSI or more. If it doesn't, you most likely have a blown head gasket.
Good Luck and Thanks. George
Aug 22, 2012 | Briggs & Stratton Garden
Oil in cylinder of lawn mower white smoke runs poorly happened after blade was changed
the engine has been tipped the wrong way oil now in chamber and will burn off eventually
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My Troy Built Self propelled lawn mower has a oil leak which results in white smoke coming from it. What is causing it? I had it for 3 months.
Hi smithjazzy8...
Check your oil level, it sounds like it has got too much oil in the crankcase.
The oil level should be to the last two threads on the fill plug threads of the engine.
This is the main cause of white smoke coming from the exaust of the engine.
Free Answer...Please take time to rate me.
May 30, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
3,249 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
