Question about Cuisinart CEC-7BK Egg Cooker Beaker with Piercing Pin
The piercing pin is not sticking out of the cup, how do I get to it
How do I get to the piercing pin
I have Keurig 2.0. I have been cleaning it. I put white Vinegar in and running it through the maker. I am now running just water, but the water is not running any better. Suggestions?
Did you clean the top of the Keurig. When the top goes down, it has like a needle point when may get clogged with coffee grounds. Get a paper click and make straight it object, I clean the paper clip the insert to point and clean out the excess coffee.
Jan 02, 2017 | Keurig Coffee Makers & Espresso Machines
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Why does the water splash around the cup rather than stream out ?
Check the removable insert that pierces the K-Cups. It may be dirty from coffee residue and needs to be cleaned. The entire assembly turns and lifts out but be careful as the piercing needle is SHARP. After cleaning, try a new k cup and see if it works ok.
Sep 12, 2014 | Manufacturer KEURIG Brewer a: Mr. Coffee...
Keurig now works ok until cup is put in
If you mean the Keurig works without a K cup in it and dose not work with a k cup in it then you need to clean the k cup holder. Take a thin wire, I use a paper clip that has been straightened out. Inside the holder is the piercing pin with a hole down the middle where the coffee goes into your cup. Clean that hole out with the paper clip.
Mar 18, 2014 | Coffee Makers & Espresso Machines
Keurig makes clicking sound but will not brew
The exit tube is clogged. Get a paper clip and straighten one end, pushing it up into the tube to clear the material out. The tube is the upper Pin Like projection that pierces the Kcup.
Jan 25, 2014 | Keurig Elite B40 Coffee Maker
I pour water in and you hear it heating but wither nothing or just a few droplets come out...
When it says descale what is really happening is that the water can no longer pass through the needle that pierces the cup. Fix : Unplug the machine. Remove the reservoir set aside. Open the lid thingy handle and turn upside down. You will see the needle that pierces the cup. That needle also channels the water. Take a safety pin or smililar object, needle etc...and pass it through the opening of the needle several times. This removes the blockage from the needle (old coffee etc). My machine works like a champ now :)
Sep 22, 2011 | Keurig B60 Coffee Maker
The water will not go through the pod to make the coffee. If you remove the pod then the water flows. If you want tea the water goes through with no problem. We tried the vinegar but that didn't work...
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
May 17, 2010 | Keurig Elite B40 Coffee Maker
Part that holds the coffee cups that pierces both top and bottom
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
May 14, 2010 | Keurig B50 Coffee Maker
Cuisinart CEC-7BK Egg Cooker Beaker with Piercing Pin Logo
29 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
