Question about Sabrent 6-Channel 5.1 3D Surround Sound Sound Card
Bought this sound card and a new microphone, but still no voice
Microphone initially stopped working, so I bought a new headset. After this still did not allow me to record voice or use ventrilo, I bought the sabrent sound card. After installing drivers, etc. I still cannot record voice. I've tried using microsoft's sound recorder and a few other programs however there is still no voice recording.
I've checked everything to do with sound options in the control panel and all the things I've seen suggested so far on this site.
Please help.
5 Suggested Answers
SOURCE: Sound card recognized, but drivers won't work
audio device not working
Posted on Aug 19, 2009
  • 691 Answers
SOURCE: i don´t know how to
Linux , Microsoft DOS , Microsoft Windows NT 4.0 , Microsoft Windows 95/98/ME/2000/XP
as far as I can see it is not compadible
Posted on Nov 19, 2009
SOURCE: I had to install your 6 channel 5.1 3d oci sound
Posted on Mar 18, 2010
  • 1027 Answers
SOURCE: good sound card to record speeches
All sound cards can record either through the microphone input or line input (in sterio) A sound recording/editing package like Audacity works very well - free downloads available.
Posted on Jun 08, 2010
Hello there, i've recently bought a terratec aureon 5.1 pci sound card and the sound work fine but my mic doesn't. its not muted or anything and i enable the right mic aswell but it still doesnt...
depending on which operating system you are using this will vary
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
hope this help you
Aug 18, 2011 | TerraTec Electronic Aureon 5.1 PCI Sound...
I have a Plantronics monoaural headset Audio 310 which is failing to give me a strong microphone signal - going through Control Panel (Sounds and Audio Devices - testing). I am using a voice to text...
Disconnect the microphone from the headset and connect another microphone to eliminate the possibility that it's bad. If the other microphone has the same symptom, then adjust the the sensitivity of the mic through the sound card properties. Or, try another sound card - it may be bad.
Feb 23, 2011 | Plantronics .Audio 310 Headset
Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
Aug 12, 2009 | Computers & Internet
Microphone in Ventrilo is too low
try on another pc in sound recorder if working there then the headset is not the problem. try uninstalling the sound card and rebooting the pc.
may correct the issue.
Dec 29, 2008 | Logitech ClearChat Stereo Headset Headset
Skype not working
Click this link for more information........
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I just bought a GE Portable headset with detachable MIC
I had the same problem, but fixed it. All you have to do is:
(I have a Dell Laptop)
1. Go to the control panel
2. Go to the sounds, speech and audio devices
3. You are supposed to see the icon that belongs to your sound card (Mine is SigmaTel Audio), click on it
4. Activate the port where the microphone is connected, close
5. Configure your microphone as you normally would
6. It should work
Oct 10, 2008 | GE (JASHO97748) (3 Pack) Headset
Microphone doesn't work
go to the control panel, sound and devices, voice test hardware there you can check your headset is working or not if working there voice playback or voice recording both check the volume if mute then unmute it
if solve rate me
Sep 27, 2008 | Intel REALTEK nc-r150201 Network Adapter
My microphone just stopped working, what can i do? My headset microphone quite working on my Sound Blaster X-Fi card when the new Creative Labs update came out......... headset/mic works on another...
If the driver is alright of course is a setting or you haven't plugged the microphone right on the sound card. See also if the micro is cut from the settings or or the volume is low. Check these first
Sep 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sabrent 6-Channel 5.1 3D Surround Sound Sound Card Logo
91 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
