Question about Refrigerators
Our Maytag refrigerator/freezer does not freeze. There is frost buildup around the coils in the freezer compartment. I manually defrosted the coils yesterday, and replaced the defrost thermostat, but today it is frosting up again, while nothing in the compartment freezes. Any help would be greatly appreciated. The unit is only about 5-1/2 years old. Thank you
    Genius:
  • 1,142 Answers
Can you please provide the model number that will help me to assist you better.
Thanks
Posted on May 19, 2009
  • Maanita Chadha
    Maanita Chadha May 19, 2009
    Poor cooling is often the result of a heavy frost build-up on the evaporator
    coils or a condenser that is clogged with dust, lint, and dirt.
    Evaporator coils
    a heavy frost build-up on the evaporator coils. You can't see these coils
    without removing a panel on the inside of your freezer. A sure sign that there
    is a build-up is the presence of any frost or ice build-up on the inside walls,
    floor, or ceiling of the freezer. Such a frost build-up usually indicates a
    problem in the self-defrosting system or damaged door gaskets.
    The
    refrigerator is supposed to self-defrost approximately four times in every 24
    hour period. If one of the components in the self-defrosting system fails, the
    refrigerator continues to try to cool. Eventually, though, so much frost builds
    up on the evaporator coils that the circulating fan can't draw air over the
    coils. There may still be a small amount of cooling because the coils are icy,
    but with no air flow over the coils, cooling in the refrigerator compartment is
    quite limited.
    Here's an inexpensive, though inconvenient, way to
    determine if the problem is with the self-defrosting system. Remove all of the
    perishable food from the refrigerator and freezer, turn the thermostat in the
    refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to
    have several towels ready in case the melting frost and ice causes the drip pan
    to overflow). This allows the refrigerator to defrost "manually." When the frost
    and ice build-up has completely melted away, turn the thermostat back to a
    normal setting. If the refrigerator then cools properly, it indicates a problem
    with one of three components in the self-defrosting system:
    • The defrost timer
    • The defrost thermostat (also called the bi-metal switch)
    • The defrost heater
    If it still does not cool properly,
    there may be a problem with the refrigerant level or the compressor. You may
    need to consult with a qualified appliance repair technician to further diagnose
    the problem
    Condenser
    Self-defrosting refrigerators all
    have a set of coils and a cooling fan, usually under the refrigerator, that need
    to be cleaned regularly. If these coils get coated with dust, dirt or lint, the
    refrigerator may not cool properly. The coils may appear to be a thin, black,
    wide radiator-like device behind the lower kick-panel. To clean them, disconnect
    the refrigerator from the power source, use a refrigerator condenser brush (see
    the Appliance Accessories section) and your vacuum cleaner to clean the coils of
    any lint, pet hair, etc. You may not be able to get to all of the condenser from
    the front, it may be necessary to clean the remainder of the condenser from the
    rear of the refrigerator.
Maytag dual cool
Frost buildup in freezer is an indication that there may be air being drawn into either the fresh food section door seal or the freezer door seal. Your model has a 61005543 Air Damper
That may also be either defective or stuck in the open position due to frost buildup. You are just going to have a look behind the rear wall of freezer to see what is going on. Unplug first before servicing. If you would like me to upload a Service Manual please let me know, John Tripp Appliance 911
Contact Me Here
Mar 09, 2014 | Refrigerators
My GE 2008 side by side , the freezer is working but the food storage is not help ?
one of 2 things can be wrong,#1) if theres a heavy frost buildup on the rear inside wall of the freezer compartment then its a defrost issue,which will block air flow to the refrigerator side,take off back panel and test defrost heater and thermostat both on evaporator coil for continuity,thermostat has to be below 32 degrees to test good,most of the time its the hearter on G.E.. #2)if no frost buildup,then check the damper vent door between the freezer and refrigerator compartments and make sure its not stuck or broken shut and can no longer open and close to keep temperatures in refrigerator cold
Sep 29, 2012 | GE GSL22JFR Side by Side Refrigerator
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Freezer not freezing
your defrost timer or defrost heater could be bad,
May 20, 2009 | Refrigerators
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
