Question about LG LST-4200A DTV Receiver
Lg lst-4200a dtv receiver - LG LST-4200A DTV Receiver
Hi, will my LG LST-5100P work in England?
Yes the digital set top box should work in the UK. When it arrives just re-scan for the channels as the UK are currently in the middle of a digital switch over.
Regards.
Dec 14, 2010 | LG LST-4200A DTV Receiver
My lg dvd case says its locked when I attempt to eject the dvd.
my lg dvd case says its locked when I attempt to eject the dvd.
Sep 23, 2009 | LG LST-3510A DVD Player/Receiver
LG LST-5100P set top box does not display menu with an older ( 1998) tv set. Cant select aspect ratios . All I can do is change channels. Any ideas? Rod
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 22, 2009 | LG LST-4200A DTV Receiver
Lg lst 5402p switching off
Failed/Failing Hard Drive I'm afraid. Contact LG.
May 05, 2009 | Televison & Video
LST 5402p firmware upgrade
How do i update my firmware on my LG LST 5402p recorder from home??
Apr 12, 2009 | Televison & Video
How to remove LG LST-4100A
To remove the LST-4100A commercial control interface from the television you need to follow the commands below.
1. Power on television.
2. Press and hold "MENU" for 10-15 seconds.
3. Quickly press "2-6-6-3" and then press "ENTER"
If you have done everything properly, it will bring up a small menu in the top left hand corner of the television. Kind of a hidden menu.
4. Arrow down to the menu option that says "D Box" and turn the option to "OFF".
Now turn off television and completely disconnect the LST-4100A. In fact, throw it away. In the trash is where it belongs.
Your television will now operate like a normal television purchased from a big box store. You should run an automatic programming setup for grins upon completing.
Enjoy your new NON-commercial lcd television.
Dec 22, 2008 | LG LST-4200A DTV Receiver
LST-3100A "HELLO" msg
Got you some help!! Open receiver up...Locate the power supply board. Locate the electrolytic capicitor "C118" and replace. II've fixed multiple LG LST 3100a receiver doing this procedure. Guaranteed to work. I hope you have not throw it away. Cheers!!!!
Sep 26, 2008 | Zenith LST3100A DTV Receiver
LST-3510A
Hello, I've been reading up on the LG LST, I got the same device. Two options that you may want to try (and there may be a third). 1st) Make sure nothing has happened to your DVI cable, make sure it is tight on both ends. Undo it and blow on the connectors and resecure it if need be. HDCP involves communication between the HDCP chip on your LST and the HDCP chip in you display. If you cable is loose, dog chewed or too long then it may be interfering with your HDCP handshake. 2nd) You should be able to go to RGB display option and dispay in HD over the same DVI cable. This was discussed much in the forums I have been reading about. I hope one of the above options helps you. In fact I hope the vacume or kids knocked the cable slightly loose and you are back in business after tightening it. The 3rd option would be to do a google search for LST-3510a and HDCP, you will find all kinds of solutions, work arounds and firmware update discussions. Good luck! Scott
Sep 26, 2006 | LG LST-3510A DVD Player/Receiver
LG LST-4200A DTV Receiver Logo
32 people viewed this question
