Question about TTX Tech Black Wireless 2.4GHZ GamePad Controller
INSTALL WIRELESS GAMEPAD CONTROLLER TO MAC - TTX Tech Black Wireless 2.4GHZ GamePad Controller
I need drivers for ttx tech wireless gamepad
the controller didnt come with a disk? the manufacturer doesn't offer drivers from what i could find. is the controller showing up under settings/device manager in the USB area? it should be there. you need to locate a program to assign the keys. PC/Mac
Mar 02, 2014 | TTX Tech Black Wireless 2.4GHZ GamePad...
Will the ttx pc mac 2 pack turbo gamepad analog controller w/usb hook up to my hp laptop
yes it is PC compliant. I also got it to work on a mac. You will need to find an emulator controller to assign the keys. some emulators have the assignment built into the emulator under preferences.
Dec 19, 2013 | TTX Tech Pc Mac 2 Pack Turbo Gamepad...
Gamepad has no response
you need to assign the buttons, usually through the emulator or a 3rd party program. several exist for free depending on OS
Dec 15, 2013 | TTX Tech Pc Mac 2 Pack Turbo Gamepad...
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
Logitech gamepad
i checked with logitech and it seems this is a common problem the controller and it is suppose to work with the mac with no drivers however it seems the design flaw is that it does not work with alot of mac games.
my suggestion get your money back or sell it on ebay and try to get a controller that works with mac
Apr 27, 2009 | Computers & Internet
Mac book got a philips game controller the cd does not work
download an app called GamePad Companion, then you can program this or any other device connected to you mac. don't bother with drivers for the p.o.s. software philips provides with the gamepad.
Jan 05, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
My nfl wireless gamepad want work
mat catz is a cheap brand, if youve had it for a while then its probably broken.
Dec 25, 2008 | Mad Catz Gamepad NFL Wireless Control Pad...
Controller detection
Jedi Academy cant play on a controller cause ive tryed to play that game before with a controller and it dont work, also look to see if that controller is MAC compatable and maybe update the driver for the game pad.
Sep 13, 2006 | Mad Catz PC Con (728658544263) Game Pad
TTX Tech Black Wireless 2.4GHZ GamePad Controller Logo
43 people viewed this question
Top TTX Tech Video Game Consoles & Games Experts
James Wishart
Are you a TTX Tech Video Game Console and Game Expert? Answer questions, earn points and help others
