Question about Swintec 7040 Typewriter
Swintec typewriter-7040 when turned on-only beeps. also, keys don't type. was away fom home about 5 months- didn't use it.
  • Swintec Master
  • 3,594 Answers
Be sure that the ribbon L/O and P/W are properly installed, move the slide switches back and forth a few times, check that no keys are stuck down, With the machine off see if the carrier will move back and forth. If not a littlt WD40 on the silver shaft it slides on will help.
Good luck
DickyO
Posted on May 21, 2009
How to reset the swintec 7040 back to factory settings
Turn off, hold down on the MR (margin release key) and turn on, machine will print some numbers and then print lines of types, let it print a couple lines then turn off and turn on.
Oct 23, 2013 | Swintec 7040 NEW Electronic Business...
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
The Swintec 7040 typewriter goes a few inches to the right and stops. How do I unlock?
My best guess is that you have the R. margin set there. Go to the stopping point, press but don't hold the MAR REL key, spce to desired location, press R. mar key.
DickyO
Nov 03, 2011 | Swintec 7040 Typewriter
Carrier stops and beeps halfway across page. How
The R. margin is probably set there. Goto that point press but don't hold the MAR REL key, space to the desired location, press R. MAR key.
DickyO
Jul 19, 2010 | Swintec 7040 Typewriter
Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
Apr 23, 2010 | Swintec 7040 Typewriter
Swintec typewriter 7040
Try spraying some WD40 on the silver shaft the carrier rides in and move it back and forth by hand with the power off.
DickyO
May 19, 2009 | Swintec 7040 Typewriter
When turned on - a beep is all i get-keys won,t work at all. 7040 swintec typewriter
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
When i turn it on it will beep every letter i enter but won't type anything it is a swintec model-600
try putting the machine in test mode. You can do this by holding down the margin release key while turning it on. Keep holding it down until it starts typing by itself. Then turn it off and on again and see if it works.
Mar 07, 2009 | Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
Feb 21, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
146 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
