Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Can it be repaired?
I have a Microtek C783 Monitor that no longer works .  It will come on but it displays blocks of color only.  I have not tried to fix it at all.  I don't want to make the problem  worse.  Can it be repaired.
I have problem with my screen
Posted on Sep 21, 2008
  • 1,006 Answers
Posted on Oct 18, 2007
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
No real problem. just wanted explnation of how to control the contrast, color, etc.
You should have settings for these via a "MENU" button on the Monitor or if you have an "optional" display card, there should be options in the "Display Driver software". Mine uses an NVIDIA GForce, Driver, and it has these options. You should be able to find this under "All Programs" in the Startup Bar - Look for something that indicates "Monitor" or "Display" in the program name.
Dec 08, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
Microtek C783 Monitor flickers when turned on
Hi there. Try to remove and reseat your video card first... maybe there's nothing wrong with it actually...
But if you check the on-screen display, like the brightness controls in your lcd monitor blinking... then you need to have it repaired or replaced.
Hope I gave you an Idea.. ^_^
Jun 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
I have no problem with my C893 monitor. I would like the best settings for it.
The manual for this monitor lists its native resolution as 1280X1024. At resolutions below this, display quality may suffer because the image may not line up with the pixels of the display. This resolution may not be supported by the integrated video in many computers.
The other settings (color temperature, brightness, etc.) are based on your personal preference. Whatever looks good to you is the "best".
Apr 07, 2010 | Microtek C893 18.1" Flat Panel LCD Monitor
Microtek c593 monitors. Out of Range
Your Minotor not support windows 7 frequincy or resulation.please open your computer safe mode, and set monitor frequincy only 60Hz. Resulation less area .Then solve your problem.
Dec 27, 2009 | Microtek C593 15" Flat Panel LCD Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Microtek monitor 997m
Try pressing and holding the menu Key for 15 seconds, that is how masy OSDs lock and unlock
Jul 01, 2009 | Computers & Internet
19" LCD comes on and goes out right away
Sep 06, 2008 | HP vs19 (Silver) 19" LCD Monitor
Color of monitor
change the moniter is the best solution, coz repair could be cost more than its worth
Jul 21, 2008 | HP CD-Writer Plus 7570i (C4411A#ABA) CD-RW...
NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
May 31, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
305 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
