Question about Dell Latitude D800 Notebook
Vertical black bar across the screen
This Latitude D800 has a vertical black 1.5" bar across the screen. The bar is visible at all times even in the BIOS scree. Any thoughts? is it the video card or the screen itself? can it be repair without replacing the screen?
  • 33 Answers
Sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
Posted on May 19, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
Appear vertical lines on screen
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can find replacement on most LCD displays on Ebay.
Dec 30, 2010 | Dell Latitude D800 Notebook
Have a 29 inch 5 or 6 yr old rca color tv lately we get a colored horizontal bar across the top of the screen and the other day we have fuzzy black lines across the entire screen
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
May 30, 2010 | Televison & Video
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Very faint vertical bar moving across plasma screen.
OK... Left to Right is weird. I'd say one of two things.
Refresh Rate might be to low or to high, but i doubt this to be the cause. I'll put my money on external interferences. Something like another PC screen? TV? anything magnetic and I've even in some cases noticed PC side panels too close to a screen can cause this.
Dec 29, 2008 | Computers & Internet
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
D800 Video Display
If you get a clean picture when connecting esternal screen, then it is just the lcd flat ribbon LCD cable that is out of place, otherwise it is the videocard.
Mar 17, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
372 people viewed this question
Alun Cox
