I need to know where I can obtain the drawings of the transmission of the different Maytag washing machines of clothes.
  • 864 Answers
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Every wash in the new Maytag Centennial washing machine has the clothes covered in bits of fluff that is almost impossible to get off. It has basically ruined our clothes. Different wash powders have been...
the solution is this..try to seperate the colored clothes to non colored clothes, seperate the cotton / silk and wool to each other, don't mix them, have them seperate set of water and dtergent
Nov 06, 2009 | Maytag Centennial MVWC500V Washer
Wontdrain nor spin
untill now ,I try to manage my problem with the washing machine.I wash then I use an external pump to **** out the water.Finally Iexpose the clothes to shiny place .
I dont take the chance to open the transmission now.My problem is the transmission is locked.I need free suggestion to keep going.
I cannot pay . Ok.
Oct 17, 2009 | Maytag Washing Machines
My maytag washing will not wash my clothes.
2 things, the control panel is faulty or the transmission is faulty. both major problems, sorry
Aug 08, 2009 | GE WBB4500EWW Top Load Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Jan 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV2755AW
All you will need is a 12002213 thrust bearing kit and new belt , the bearing comes with instructions , lay unit on front to do this you schooled not need a transmission
Aug 12, 2017 | Maytag PAV2300 Top Load Washer
The clothes were not dry enough.
either motor or pump.
Clean filter first and if that does not help check the transmission
HERE you can find drawing and parts
Apr 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Not spinning level
this preforma machine was not built by whirlpool but by maytag. the problem is the snubber ring on the bottom of the transmission. it has some foreign substance on it part number for the snubber is 21002026, transmission will have to come out to be replaced
Apr 12, 2008 | Washing Machines
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 06, 2007 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
