Maytag lat9605aae Washer works normally until spin cycle, where it simply refuses to spin. However, when checking the operation in the delicate cycle, the spin cycle works normally. This leads me to believe it isn't a mechanical issue, but likely the timer or control board. Checking the machine's operation confirms that the motor and pumps seem to be working.
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Posted on Apr 09, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
tzweeb
  • 318 Answers
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Posted on Jan 06, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Posted on Jun 20, 2009
Testimonial: "Awesome help and advice -- thank you to everyone!"
Does not agitate, rinse or spin in normal cycle, but works on delicate cycle
YOU NEED TO LOOK IF THE POWER BELT IS BAD OR NEED ADJUST.WHEN POWER BELT NEED SERVICE ALL OF THE SYMPTOMS YOU WRITE ARE COMMON.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 03, 2011 | Maytag Washer Timer - 22004015
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model LAT9605AAE serial # 13662937QD washer gets out of balance constantly on every spin cycle
make sure all of the legs are adjusted correctly. maytag washers also have to be on a very stable floor. if the floor is not stable or if the legs are not adjusted properly then the machine will shake all over as if they are out of balance.
Jul 01, 2008 | Maytag Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Maytag PAV1000AWW washing Machine
Your machine has a two speed motor. If the motor hums as it tries to spin in the normal cycle, it could be the motor. If there is no noise, it could be a timer related issue.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
